Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Dyno 180hp-190tq
Old Nov 18, 2003 | 06:21 AM
96max5sp's Avatar
Dyno 180hp-190tq
I went to the dyno saturday and got 180hp and 190tq, is this right for the mods i have, I was expecting a little more and was dissapointed. I have a UR flywheel, Budget y-pipe, Definitive UDP, and Frankencar intake with an Apexi filter, at least those are my power mods. I also have a Exedy clutch, KYB AGX struts and Progress springs, and 17" ADR concept pro wheels (16-18lbs each) with HTR + tires. If this is normal thats fine but i was expecting at least 185-190hp. Isn't stock like 160hp? I only got 20hp with all my mods? Anyway i make my peak torque at 3250rpm and my peak hp at 5250rpm. The curves are pretty smooth except at 3250 there is a hill, then the torques drops 10 and horsepower about 2hp. Then it starts going back up but the line looks a little shakey the rest of the way. Is this normal? I just looked at the other post here and it looks alot smoother the line not as squiggly, mine ain't bad but not that smooth either. Sorry for the long post just trying to get some answers and i don't have a scanner. Thanks.
P.S.- I am probrably just jealous cause the GTI's that were there were getting 200hp and 225 torque. Time to get some FI
P.S.S - by the way the dyno was done in 4th gear
Old Nov 19, 2003 | 10:38 AM
MAXimumHP's Avatar
I would say your numbers for peak power sound about right. The lightened flywheel and pulley won't show up much on a dyno, especially in 4th gear. Many people dyno in 3rd on Maximas. Your peak torque seems to happen a little bit too soon. I'm not an expert, but I think peak torque should be closer to 4K rpm or higher. Normally I think peak HP rpm is a bit higher as well. If you could post the graph, that would help a lot.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Chebosto
Dec 19, 2001 06:34 AM
Nismo87SE
Oct 23, 2000 08:15 AM
