Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Accuracy of Dyno's
Old Feb 18, 2004 | 04:18 PM
chris'smax's Avatar
Accuracy of Dyno's
After looking at some dyno silps I noticed some maxima's with the same year model, transmission, and mods had different hp readings up to 10 hp in difference. Is this do to the accuracy of different dyno's or is this a result having either a fed spec or cali spec?(I thought i remember someone saying that the cali spec was a bit more restrictive due to the admission standards).
Old Feb 18, 2004 | 04:21 PM
bigdo26's Avatar
has to do with a variety of different conditions. Temp, humitity play a significant part. The actual dyno's are quite accurate
Old Feb 18, 2004 | 04:29 PM
chris'smax's Avatar
I knew the temps played a role, but i didn't know it is significant enough to give a difference of 10hp
Old Feb 18, 2004 | 05:39 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
There's about a zillion different variables.
- general maintenenace stuff (plugs changed, etc)
- Air filter dirty/clean
- Tire pressures consistent
- Alignment
- Type of tire
- Larger/heavier rims vs smaller/lighter ones
- Engine heat soaked or not
- different combinations of mods
- fuel quality and/or fuel formulation
- the actual dyno (there are different types of dynos)
- SAE, STD or NO correction being used on the dyno (should be using SAE)
What's important are the before and after dynos on each car. That's the true test of how a modification responds. Don't read too much into Car A with mods vs Car B with the same mods because it's a given that it's a different car, but also different dynos, probably a few things different here and there, and the dynos are different also. There's just too many variables.
Old Feb 20, 2004 | 08:16 AM
MrEous's Avatar
^ Jeff™
Here is a GREAT thread on SAE vs STD correction factors...from a Zo6 board.
http://www.z06registry.com/forums/sh...threadid=40259
Old Feb 23, 2004 | 03:10 PM
nadir_s's Avatar
vicodin ... gift of life
- Alignment
- Type of tire
that's some good information. I'm a total newbie to interpreting dyno charts and this helps me out a little bit. Perhaps you can make this a sticky or maybe add some more info on how to interpret these charts!
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Daniel B. Martin
21
Dec 2, 2002 05:55 PM
Chebosto
Dec 19, 2001 06:34 AM
Nismo87SE
Oct 23, 2000 08:15 AM
