Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
226tq NA with 3.5
Old Dec 9, 2004 | 07:38 AM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Why not?........
Originally Posted by krismax
Very nice but i wouldnt want that for the street
Old Dec 9, 2004 | 09:01 AM
  #42
Broaner's Avatar
2060lbs and falling...
I forgot about the Brake Booster. PCV isn't required though. Mine is disconnected from the IM. I just capped the nipple. That Z hung in there well with the 944? in the SCCA runoffs. Its a real beast. Nice pics.
Old Dec 9, 2004 | 09:51 AM
  #43
krismax's Avatar
Father of the 00 VI
Originally Posted by IceY2K1
Why not?........
I nwas thinking of money wise getting it to work without a standalone prob not possible you need TPS to work and maf somehow to read all those inlets $$$$$$$$$$$
Old Dec 9, 2004 | 11:01 AM
  #44
IceY2K1's Avatar
Good point.......
Old Dec 9, 2004 | 12:57 PM
  #45
TILLEYS99's Avatar
Lives in a 11sec maxima
tps and map sensor will do away with the maf
Old Dec 9, 2004 | 07:13 PM
  #46
98SEBlackMax's Avatar
Maxima.org Insomniac
Yup a MAF to MAP conversion could be done if someone was to put in the time. And Krismax I think the SMT6 can do this.
Old Dec 9, 2004 | 07:16 PM
  #47
TILLEYS99's Avatar
NEW MOTOR PICS
Old Dec 10, 2004 | 01:52 PM
  #48
JClaw's Avatar
Full 3.5? Or are you sill using minor VQ30 components?
Well the motor is gone now and new trans and motor are in progress!
Err... what happened? Blew it up?
Old Dec 10, 2004 | 01:59 PM
  #49
IceY2K1's Avatar
He's dumped the CVTC and probably using JWT VQ30 cams, if it's going in one of his cars, otherwise just VQ30 stock cams.
Old Dec 10, 2004 | 02:41 PM
  #50
TILLEYS99's Avatar
well 3.5 heads/bottomend/IM with 3.0 chains/timing cover/sprockets/JWT 3.0 cams Old motor was sold this one was a flod damage and didnt want to put it in a customers car so i just swapped em.
Old Dec 10, 2004 | 02:46 PM
  #51
IceY2K1's Avatar
To repeat StephenMax, were any modification needed to fit the VQ30 timing cover to the VQ35 block/heads?
Hmmmnnn....this swap sounds PERFECT.
Old Dec 10, 2004 | 03:26 PM
  #52
TILLEYS99's Avatar
from the chain side there are 3 bolts that hold the cam end cap too the timing cover. the center one is off by like a 1/4 inch needs reamed out too fit, but thats the only problem. Also 3.5 IM needs a TB with cable/tps and a IAC hooked up.
Old Dec 10, 2004 | 03:56 PM
  #53
JClaw's Avatar
Cool... did you drive it around yet? Does it pull harder with the 3.5 heads/IM?
Any reason you didn't keep the 3.5 timing chain? Why would the 3.0 TC be better? Pathfinder 70mm TB?
Also are you using JWT 3.0 cams rather than VQ35 cams so you didn't pay for them for nothing?
Old Dec 11, 2004 | 06:39 AM
  #54
TILLEYS99's Avatar
NO its not in yet I had to use the 3.0 chain too be able too use 3.0 ecu. JWT 3.0 cams have more lift than the 3.5s. And im using the 2k2 TB (heavily modded too cable TB)
Old Dec 11, 2004 | 09:09 PM
  #55
japmaxSE's Avatar
Go Get a Life!
Tilley would you consider aiding in pumping more fuel and having a higher octane than 93 with the 3.5/3.0 setup?
Would this be beneficial with an 11.5:1 comp thus creating more power?
I was told with that comp and 100 oct you would see substantial gains.
Old Dec 12, 2004 | 09:56 AM
  #56
TILLEYS99's Avatar
It wouldnt hurt
Old Dec 13, 2004 | 08:08 PM
  #57
95BLKMAX's Avatar
Hey tilleys, if you use 3.5 heads, you'd be using the 3.5 exhaust manifolds as well right? If you do, how would you go about fitting the y pipe? Can a regular y pipe from a 3.0 4th gen fit the 3.5 headers and clear everything, or use a y pipe for the 5.5 gen instead, or would you just make a custom y pipe?
Another thing, you're using a "heavily modded" 2k2 TB, would the 3.0 TB's mounting holes line up on the 3.5 VI or is the modded 2k2 a must?
My god this is even MORE tempting than the 3.5 bottom end hybrid (drooooooooooooools :-D).
Old Dec 14, 2004 | 03:13 PM
  #58
TILLEYS99's Avatar
use stock manifolds from 3.0. 3.0 tbs will not work without mods on 3.5 IM
Old Dec 14, 2004 | 06:54 PM
  #59
95BLKMAX's Avatar
thanx. This is some great stuff that you Tilley and SR20 do. So if you run the 3.0 manifolds, does the EGR tube match to the 3.5 intake manifold or do you remove it? Also would one have to run the 3.5 flywheel and clutch or 3.0 stuff?
Old Dec 14, 2004 | 08:00 PM
  #60
Broaner's Avatar
I would imagine EGR is being plugged up. As far as the flywheel there really isn't a difference except maybe bolt pattern but I think the clutch and pressure plate is larger. Unless Nissan used a more agressive disc material there would be no way for the same clutch from the 3.0 to hold up long term to the power of the 3.5 without being bigger.
Old Dec 20, 2004 | 04:52 PM
  #61
95BLKMAX's Avatar
Hey Tilley, me and some other Maxima guys down here in Miami were wondering if there was an update on the 3.5 engine/3.0 Timing stuff hybrid motor.
Old Dec 21, 2004 | 06:31 AM
  #62
TILLEYS99's Avatar
Well i had some other priority's but it should be running by xmas
Fbana41
Aug 29, 2016 12:18 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
09maxshawn11
Sep 30, 2015 10:28 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
MaxRPM6
Sep 11, 2015 06:56 PM
