Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
226tq NA with 3.5
Old Dec 4, 2004 | 12:50 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
226tq NA with 3.5
Well today I dynoed my girls 97 max with a 3.5/3.0 heads cams, headers, 00VI wired completely open.
226hp/205.4tq
Old Dec 4, 2004 | 12:55 PM
Zack342's Avatar
nice numbers but graph would be excellent. Are these numbers on a dynojet?
Old Dec 4, 2004 | 12:57 PM
TILLEYS99's Avatar
Old Dec 4, 2004 | 01:07 PM
Zack342's Avatar
Little hard to see but i am going to assume the top is the HP and middle it TQ. Th Hp looks wonder as it peaks out at redline and that has to be the FLATTESt TQ curve i have ever seen in my life.
good job man you built an excellent motor.
Old Dec 4, 2004 | 01:10 PM
TILLEYS99's Avatar
BTW thats was with NO ECU upgrade so 6400rpm. tops HP/bottoms TQ
Old Dec 4, 2004 | 02:01 PM
TILLEYS99's Avatar
well 2k2 full swap coming in the next week, but run off 4th gen ecu
Old Dec 4, 2004 | 03:57 PM
JClaw's Avatar
We'll see the difference that the lack of VTC makes...
Old Dec 4, 2004 | 04:03 PM
TILLEYS99's Avatar
We will see very very soon
Old Dec 5, 2004 | 10:08 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Did you get the SAE numbers?
Any way you can email that picture to me, so I can read it better?
Try and get the files on disk, since they're alot easier to read/compare.
Old Dec 5, 2004 | 10:12 AM
TILLEYS99's Avatar
Not sae #s
whats your email?
Old Dec 5, 2004 | 10:41 AM
IceY2K1's Avatar
It's in a PM from the other day.
Old Dec 5, 2004 | 04:05 PM
stephenlc's Avatar
man that torque curve us so flat, looks like viper dyno. It probally stays flat because you had the intake manifold completely open the whole time. It looks like with a higher rev limiter, you would keep making power.
Old Dec 5, 2004 | 04:16 PM
TILLEYS99's Avatar
I had a ecu on it earlier this week but had to give it back and it pulled like he!! too 7300
Old Dec 5, 2004 | 05:36 PM
imported_JIC_A33
wow..im not impressed
Old Dec 5, 2004 | 08:29 PM
TILLEYS99's Avatar
Well if you not impressed then dont post!! Considering im using 3.0 heads thats a draw back. And considering the highest all motor max dyno is like 250whp with a full 3.5 i think its decent, especially with my baby 55mm TB
Old Dec 5, 2004 | 10:28 PM
Ghase's Avatar
226hp/205.4tq
Great numbers, your car makes more power on the dyno then most 02-03 maxima's I've seen. And if they make more then you, it's usually because of headers and a TS ecu upgrade along with the rest of the bread & butter mods.
PS Your using 3.5 upper engine parts right, and how much did it run you??? I thinking about doing the samething to 2k max. That and some JWT cams.
Old Dec 6, 2004 | 05:52 AM
TILLEYS99's Avatar
It dont cost me much, just price off parts, I have my own business.
Old Dec 8, 2004 | 07:58 AM
IceY2K1's Avatar
Tilley,
Did you get any 3rd gear pulls by chance?
Old Dec 8, 2004 | 08:54 AM
TILLEYS99's Avatar
Tilley,
No just 4th
Old Dec 8, 2004 | 11:59 AM
stephenlc's Avatar
dude,that torque curve looks like what happens to a torque curve on a honda after vtec. That torque curve stays flat and 9000+ it keeps making power with a flat torque curve. If you had a higher rev limit, I bet you would make a whole lot more power.
Old Dec 8, 2004 | 01:36 PM
Cutler's Avatar
What did your's dyno?
Old Dec 8, 2004 | 01:44 PM
IceY2K1's Avatar
Says in his profile or should I say 02 SE/92 SE-R 02 SE's profile:
"02 6spd, every opt but Nav. JICs, FC intake, cattman Y-pipe, RSB, FSTB and Toyo 4s 217.9 WHP 227.6 TQ"
Old Dec 8, 2004 | 01:55 PM
Cutler's Avatar
I wasn't trying to flame, just asking to see a comparison
Old Dec 8, 2004 | 01:58 PM
IceY2K1's Avatar
He's been banned twice already..make it three now.
Old Dec 8, 2004 | 02:06 PM
TILLEYS99's Avatar
Well the motor is gone now and new trans and motor are in progress!
Old Dec 8, 2004 | 02:10 PM
Cutler's Avatar
I wasn't trying to get him banned.......
Old Dec 8, 2004 | 02:12 PM
IceY2K1's Avatar
His being banned before for WHATEVER reasons by two different moderators is why he's got banned.
Next, is IP ban if Sprite gets bored.
Old Dec 8, 2004 | 05:19 PM
krismax's Avatar
Father of the 00 VI
with having a small TB and having no ecu,that dyno is great . He made peak HP at fuel cut imagine better TB and a ecu going to 7500rpm . I say 245whp @6900rpm.
Old Dec 8, 2004 | 06:20 PM
IceY2K1's Avatar
I say screw the VQ30 or VQ35 intake manifolds and make a simple single chamber short runner one like the UNIVERSAL ones these guys sell. Yes, some torque will be lost, but with the VQ35 bottom end or boost, that's not a problem.
http://www.rossmachineracing.com/
Old Dec 8, 2004 | 08:11 PM
krismax's Avatar
Father of the 00 VI
this is a great find i can have this made very easy,never thought of this. I have a idea on how i want mine done.
Ice do they sell the round tubes also?
Old Dec 8, 2004 | 08:31 PM
Broaner's Avatar
2060lbs and falling...
I've always wondered why someone doesn't just go for the full on log/short runner setup. Seems this would be much more benificial for boosted cars but still. Without the curves of the UIM there are gains to be had right there. All you need is vacum for FPR right? None of that EGR BS. Just IACV and one vacum nipple. Question is, what happens to midrange with this type? Hey, if gains are minimal at least changing plugs would become even easier.
Old Dec 8, 2004 | 08:45 PM
IceY2K1's Avatar
I didn't see round, if they do, however square and semi-circle.
I think you'd want the flat surface to weld too. Besides the TB mount, all you'd need to add is those venturi pieces to some kind of plate that mounts to the LIM, right?
Old Dec 8, 2004 | 08:46 PM
krismax's Avatar
Father of the 00 VI
Nipple at rear for brakes ,nipple for FPR which is in my 00 vi adapter block .IACV I would do the same way as my 00 vi worked out (adapter block). But the only thing would be PCV you would have to dump it into the IM you could use oil seperaters to clean it.
I could make this easy but i know nothing about flow or anything to do with making a good IM. But i may try anyways prob not till i start working at the machine shop again. I would use the lower IM that comes stock,and weld my setup to the top of that with port matched plenums.
Old Dec 8, 2004 | 08:49 PM
IceY2K1's Avatar
Or IMHO...a perfect DPI N20 setup.
krismax's Avatar
Father of the 00 VI
Ok if you click your link in the upper left you see a half round with round tubes welded together is that the ventuari pieces? If so i wonder what the lower inside diameter is because they would have to weld to the lower IM.
Old Dec 8, 2004 | 08:53 PM
IceY2K1's Avatar
Not sure, but I think they're calling them "velocity stacks" and selling them for $39/each.
Anyways, I guess you could make it one piece by welding it to the LIM, but why not just weld the venturis to a flange that bolts to the LIM instead?
Old Dec 8, 2004 | 09:00 PM
IceY2K1's Avatar
Or you could do like this VQ30 equipped 350Z:
http://www.nissanperformancemag.com/july03/goughary/
Old Dec 8, 2004 | 09:01 PM
IceY2K1's Avatar
Hey Chris, notice the VQ35 valve covers with VQ30 timing chain cover?
Old Dec 8, 2004 | 09:14 PM
krismax's Avatar
Father of the 00 VI
Very nice but i wouldnt want that for the street
Maybe a flange could be done ,i always do what easier though.
Looks like others have done hybrid vq's and those valvecovers are the plastic fix i need (dont tell dave b they may warp from the heat ) Also ive held those at tilleys shop they are so much lighter
Old Dec 9, 2004 | 05:27 AM
TILLEYS99's Avatar
that motor look just like the one layin here in my garage minus the IM
