Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
4th Gen Auto with 3.5 Dyno'd
Old Jun 14, 2005 | 12:28 PM
Dubbya's Avatar
VK56 Inside
Please keep in mind that this is stock 4th gen timing.
Check page 7 for the dyno at the bottom.
http://www.cardomain.com/profile/dubbya512
Warner
Old Jun 14, 2005 | 12:44 PM
cardana24's Avatar
Blown
Warner
is your car automatic?
Old Jun 14, 2005 | 12:50 PM
Dubbya's Avatar
VK56 Inside
Yes its an autotragic.
Old Jun 14, 2005 | 01:48 PM
vsamoylov
you need a manual man. kinda low though and you need to do something about the air to fuel ratio as well especially at 4.5. anybody have a dyno graph like that for a manual?
Old Jun 14, 2005 | 01:51 PM
Dubbya's Avatar
VK56 Inside
so the a/f is running a little rich? I have only had the car like 2 weeks now and this is the 1st dyno. I am sure there is lots of bugs/tuning to be hammered out yet.
Old Jun 14, 2005 | 01:56 PM
vsamoylov
you are running lean at 4.5 k. i cant remember waht the stock a/f looks like though.
Old Jun 14, 2005 | 02:06 PM
Dubbya's Avatar
VK56 Inside
I thought lean was good for h/p though?
Old Jun 14, 2005 | 04:08 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
13.5 A/F is good for short bursts of speed for the 1/4 mile and such. 12.5~13.0 is better for track racing or any kind of long endurance racing to keep your EGTs down.
Also do you have a catalytic converter in there? If you have a cat in place your A/Fs will be off. From my experiences the A/Fs were leaner when I had my cat converter in place. I used a test pipe and my A/Fs were very rich, but not anymore...
Old Jun 14, 2005 | 04:11 PM
at 4.5K hes running his richest, near the top end hes at 13.5. If you were to lean out that dip from 4000~5250 you would pick up some power.
Old Jun 14, 2005 | 05:02 PM
NmexMAX's Avatar
dot dot dot ...
vsamoy .. that's the 2nd time you make that mistake, but who's counting ... Also, what about the SAE #'s, because on there I see STD ..
Old Jun 14, 2005 | 10:07 PM
vsamoylov
yeah i was just looking at it closer and realized that. for soem reason i had the graph upside down and was thinking lean was 4.5 k. i think i need glasses. lol.
Old Jun 14, 2005 | 10:21 PM
NmexMAX's Avatar
dot dot dot ...
I don't think you need glasses, but a dyno would help ...
Old Jun 15, 2005 | 07:54 AM
Dubbya's Avatar
VK56 Inside
I am running a stock cat. I do have a test pipe, I just dont want to run around with it on. Next time I dyno I will put on the TP to see what happens. Thanks for all the input guys!
Old Jun 15, 2005 | 08:26 AM
steven88's Avatar
Need A Light?
isn't 12 AFR @ 4.5k pretty damn good? and hes hitting pretty damn good AFR's after 5k...From what I heard the stock 2k2 runs really rich after 5500 revs...as rich as 10-11 AFR....
Dubbya aren't you using components off a 3.0? Hmm...maybe thats why....a stock 3.5 with all it's components still intact would probably run real rich above 5500.....wheres a 3.5 with some 3.0 components (timing cover, TB, ecu, etc etc...) would not run as rich
Old Jun 15, 2005 | 08:43 AM
Dubbya's Avatar
VK56 Inside
I am using the following set up:
3.0 Timing system
3.0 ecu (stock)
02 Pathy TB
3.5 Cams (redrilled)
Old Jun 15, 2005 | 09:50 AM
gameover03's Avatar
out of curiousity how much did work and labor run u...?
Old Jun 15, 2005 | 09:52 AM
gameover03's Avatar
if you dont mind me asking..?
Old Jun 15, 2005 | 10:26 AM
Dubbya's Avatar
VK56 Inside
I do not mind you asking, but please send me a PM. I dont want to sway from the original point of this post. Thanks man.
Warner
Old Jun 16, 2005 | 07:38 AM
PlanoSER's Avatar
Hey, was this dyno done @ Alamo during the Maxus event last weekend? j/w I was there & dynod my Altima too but got there kinda late.
Old Jun 16, 2005 | 08:43 AM
Dubbya's Avatar
VK56 Inside
Yes that is were I got it done. I saw your alti dyno. Pebble Beige right?
Old Jun 16, 2005 | 01:12 PM
SmokinOdum's Avatar
Nope, it's a white alty. I was up on the dyno around 9:30pm or so
Edit: sorry posted this while logged in under my brother's name.
Old Jul 14, 2005 | 03:21 PM
E55AMG2's Avatar
Wat
Looks like you need some headers now
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Blackwind
Aug 5, 2015 06:35 PM
