Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
188mph top speed dyno
Old Apr 10, 2006 | 08:51 PM
inspiredbykev's Avatar
You should thank my D***
1st pull 4th gear at 2krpm 230.87 hp 228.46tq
end result after tuning 237.63hp and 238.49tq
did a top speed test which I stopped around 6500 rpms 188mph. I should've went to 7100 rpm probably could've hit 190mph.
sae corrected
will try to post video
Old Apr 10, 2006 | 08:53 PM
NmexMAX's Avatar
dot dot dot ...
Run files???
Are those #'s STD/SAE Uncorrected?
You have TS L-spec or full spec?
Old Apr 10, 2006 | 08:55 PM
Puppetmaster's Avatar
What he said... run files, graphs, correction factors?
Old Apr 10, 2006 | 09:00 PM
ts l-spec ecu
Old Apr 10, 2006 | 09:08 PM
Originally Posted by inspiredbykev
Btw, those all link to RunFile_001. I still managed to download 1-8 though.
Did you tune the SAFC-II at all? The A/F past 5500 is all < 13:1.
Also, if you have an L-Spec, why did all the runs stop before 6500 rpms?
Old Apr 10, 2006 | 09:15 PM
Anyways, regardless, those are pretty decent numbers.....
Old Apr 10, 2006 | 09:24 PM
the guy was tuning the safc-II
in the computer the kid put it to 6800 rpms
he said the power drops down after 6200 rpms
Old Apr 10, 2006 | 09:31 PM
I think this is the graph most people would want to see:
I dropped Runs 7 and 8 because they weren't very useful....
Old Apr 10, 2006 | 09:35 PM
Not sure that he did a good job...
Not sure that I understand what you're saying. Do you mean to say he stopped the dyno after 6200 rpms? What's the point of the extended rev limiter then?
Btw if he tuned it right and leaned it out after 5500, you might not be dropping at 6200.... its really rich there. Heck you could lean it out more from 4000 even.
Old Apr 11, 2006 | 06:09 AM
NmexMAX's Avatar
dot dot dot ...
Can you send me the runfiles? One of you... bizzy1999@hotmail.com
Old Apr 11, 2006 | 07:11 AM
SR20DEN's Avatar
VQ Wizard
OE Tach FTL.
The OE Tach does NOT read accurately. You have to take it to 7000 in order to get your first 6600. My Tach goes all the way to 8000 before I actually get to 7500.
You would have hit over 200mph had you gone to your rev limit.
Old Apr 11, 2006 | 07:14 AM
NmexMAX's Avatar
dot dot dot ...
224 @ 7000 'top' of 6th.
188 = ~ 5900 RPM in 6th.
With original size tires of course.
Old Apr 11, 2006 | 07:36 AM
You have email....
Old Apr 11, 2006 | 01:24 PM
DAVE Sz's Avatar
Hooooooonda.....
too bad air resistance will never let you go that fast.
Old Apr 11, 2006 | 03:40 PM
HotshotVQ35's Avatar
Old Apr 12, 2006 | 04:42 PM
HallKemar
someones lyinggggggggggg
Old Apr 12, 2006 | 04:43 PM
WTH are you talking about?
Old Apr 12, 2006 | 04:58 PM
SR20DEN's Avatar
VQ Wizard
Someones not paying attentionnnnnnnnnnnnn
Old Apr 12, 2006 | 05:58 PM
whats up fellas
I'm debating if I should get the racing street pipe thats on custom maxima. On my dyno I had the cattman fastcat. Its a highflow cat and its pretty small. Would the car have breathed better and pulled harder on the dyno with the street pipe?
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
Sep 27, 2015 08:37 AM
