Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
disappointed in dyno numbers
Old Dec 21, 2006 | 07:56 AM
amomaxima's Avatar
I had my 2k max dynoed the other day and i was real disappointed in the results and i was wondering if anyone new why. I have the following mods done to the motor:
Cattman CAI
Cattman Y pipe, fast cat, cat back
DIY Grounding kit
AFCII(with dyno tuning)
Timing advance.
WIth these mods i only dynoed at 166 hp and 190 tq
SERIOUSLY if anyone can help me with this i would GREATLY appreciate it. I was told that the SES light can effect the HP rating of the motor so i had that cleared and checked.
I would really like someones input on these numbers, i think they are low for the potential that this engine has.
thank you in advance for all your help.
Old Dec 21, 2006 | 07:58 AM
Puppetmaster's Avatar
Do you have a chart? Better yet, did you take a copy of the runfiles?
Is your VIAS working? Irish44J had similar numbers to yours with a broken VIAS.
See: http://forums.maxima.org/showthread.php?t=466415
And other threads in that forum.
Old Dec 21, 2006 | 08:01 AM
eng92's Avatar
This should be in the DYNO forum.
A single hp/tq number is useless. Post up the hp/tq vs rpm curves and you will get some informed responses.
Old Dec 21, 2006 | 08:03 AM
jeff5347's Avatar
Do you have the vq35 w 255 horse and torque? I can tell you this that the grounding kit wont show you anything. Think about it if your car wasnt grounded correctly your car would not start lights wouldnt work and stereo wouldnt turn on. The ground kit is a money making deal. I work on much higher HP engines than the Maximas and a good ground is all you need. Did you advance the timing thru the ECU? What is the advetised hp rating of your engine? Also what trans you have.. a manual or auto. Autos typically eat about 25% of the engine power due to needed that energy to turn the parts in the trans as well as the friction prduced by the fluids. A manual will take about 10-15% powerr away.
So a 200 hp engine will theoretically will have 175 WHP
Damn dude, give me some time to move it....
Old Dec 21, 2006 | 08:42 AM
amomaxima's Avatar
i dont have the rpm curve i havent gotten the disk form the guy yet but i am goin to repair the VIAS before i post the curves
Old Dec 21, 2006 | 05:24 PM
NmexMAX's Avatar
dot dot dot ...
Official #'s from Nissan are 255 hp and 246 lb/tq. And no, he does not have that engine. This can be verified by the year of his car, which is a 200. The VQ35 came in the 02+ Maximas.
How else would you do it? Turn the distributor? Tak MAF V out...
The advance the original poster is referring would not have any affect on peak #'s.
222.
Wouldn't it depend on the tranny
Old Dec 21, 2006 | 10:26 PM
96blkonblkse's Avatar
A graph would be very helpful. The 00-01 have the VQ30DE-K. The 02+ got the VQ35. Bone stock 4th gens with there usim have dynoed higher then that. Most of them dyno in the mid 160 range. You should be a lot higher then that considering you already have the variable intake. I think your VIAS could be broken.
Old Dec 22, 2006 | 01:03 AM
V8KO's Avatar
dynojet or mustang dyno. I believe the mustang dyno shows less whp.
Old Dec 23, 2006 | 12:52 PM
amomaxima's Avatar
i dont know which dyno it is but i will be looking into fixing the VIAS
HOWEVER
i checked the vias and it moves at 5k plus on th rpm guage so i am confused. WIll it move and not work.
Old Dec 23, 2006 | 03:04 PM
NmexMAX's Avatar
dot dot dot ...
It's possible for it to move and not work, yes.
Old Jan 20, 2007 | 10:39 PM
h82brag2u's Avatar
what is VIAS???
Old Jan 21, 2007 | 04:54 AM
clborden's Avatar
Originally Posted by h82brag2u
what is VIAS???
Wow dude. To avoid being flamed I would definately do a little more reading before posting a question like this. It means variable intake that came on the 2000-2001 VQ30DE-K engine.
Old Feb 10, 2007 | 05:37 PM
arthur glazier's Avatar
I have a 2000 auto with 130,00 miles with headers, underdrive pulley, grounding wires,injen intake and moded b pipe,with the spark advance and i dynoed at 182hp/175tq/ Ive been low on power hp/ever since new.the 3.0 just dosent take mods very well.It might be the ecu,no one can do anything with it.I hate to brake it to ya dude,but good luck
Old Feb 10, 2007 | 06:32 PM
NmexMAX's Avatar
dot dot dot ...
That's your problem.
Old Feb 12, 2007 | 08:28 PM
or maybe there is something wrong with the engine. Considering your an auto, your numbers are not that far off what they should be. headers would give the most significant gains, while udp, gorunding wires and intake giving minimal gains. Id say you should be around the 190 range.
I am reffering to Arthur Glaziers comment.
I dont think its the 3.0 that take power well, because a 3.0 in a 4th gen 5spd with intkae, ypipe, catback puts down around 180hp/185tq. Although your guys top end is much better.
Old Feb 14, 2007 | 06:30 PM
I did not mean all 3.0 engines. I mean the maxima engine made for the 2000-2001 models. Your correct the 4th gens put out better num. but they use a different ecu then 2000-2001 do.and dont they have 1 cat and 2 o2 sensors,+ less smog stuff.too.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Sep 27, 2015 08:37 AM
