Dynoying an auto
Dynoying an auto
So I've been reading around and I've been seeing two different answers. One was that I should use 2nd gear to dyno but then I'd see another answer saying that I should use 3rd gear but start at around 3300rpm. Which one is true?
http://forums.maxima.org/dyno-discus...no-thread.html
3500 RPM, whatever speed that is in 3rd is a good start. See what works for you, i.e. when it DS's, etc.
3rd gear is best - start wherever you can so that the car doesn't downshift. Lock out the overdrive. I don't care about anything under 3000 RPM - that's where I launch from - but preferences may vary.
I assume its no different, but you never know.
^^^ hmm just making sure... just a glimpse of what my numbers should look like... lemme as you suttn... was the SSIM worth it??? i heard unless you have a TS ecu then you probebly lose power.... and was your 1/4 times with all the mods???
Definatly worth it the 70 to 100+ pull is amazing, it screams all the way it makes it seem the power is endless. TS and auto
and yes that is my PB but I can definatly improve we'll see how I do on Wed. with the SRI.
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
