Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
N/A and Nitrous
Old Dec 13, 2009 | 10:08 PM
shift_123456R's Avatar
N/A and Nitrous
All numbers are untuned, and vafc2 was used to bump up fuel to run rich for safety reasons. All motor run -3 fuel was used all across the charts to lean it out a bit.
Dyno is a DynoDynamics.
All motor 257whp
Nitrous - 390whp .62nitrous .35 fuel
Clutch was slipping badly and nitrous was only sprayed to 5200rpm, so there was still some power to be made. I was just playing it safe.
No my motor is not built. I put the car together with the help of many people. Sandeep (PunjabizMax) gets most of the credit. He has been the mechanic of my car and helped me thru every step.
Homedepot 3" PVC pipe w/ Spectre Filter
OBX Headers w/ 3" flex section
3" Summit Cut-Out
2.5" Crush Bent BS Exhaust w/ Stock Muffler
Ported Upper, Lower Manifold w/ NWP Blockoff Plate no SSIM
Stock Injectors
Walboro 255LPH
AEM Wideband
VAFCII
Stock Clutch, Stock Flywheel, No LSD, No ECU, Stock Axles
135K Miles on Motor
Any further questions. Feel free to ask.
Dyno graph will be uploaded soon, just waiting for scanner to finally work.
Old Dec 13, 2009 | 10:40 PM
krazy6's Avatar
Badass numbers man!
Just get a clutch in it and you will be good to go.
That would be a sick street race car. Not saying that you do that or anything lol.
Old Dec 14, 2009 | 06:11 AM
mist max2000's Avatar
nice numbers
im guessing your NA numbers are with the cutout open?
and...
do you have the oem maf in that 3" hd intake or what?
Old Dec 14, 2009 | 09:15 AM
Originally Posted by mist max2000
nice numbers
and...
yeah stock maf and open cutout
Old Dec 14, 2009 | 09:20 AM
ajcool2's Avatar
Seen this in person, very impressive!
Old Dec 14, 2009 | 05:44 PM
krazy6's Avatar
Impressive for sure! Nitrous FTW!
Old Dec 14, 2009 | 06:03 PM
2002AltimateV6's Avatar
390WHP, yeesh! Definitely capable of 400+ when you wring it out to redline. 150 shot I'm assuming?
Old Dec 14, 2009 | 06:08 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Yeah that's 150 shot jetting. I'd like to see what the torque peak was.
Did the dyno shop not give you runfiles? Call or email them and say you want runfiles sent to you.
Old Dec 14, 2009 | 07:47 PM
got some Q's for ya...
how many step colder plugs are you running..?
who did your IM porting..?
ever do a N/A run with the cutout closed..?
150shot i would blow my **** up lol.. ever run at the track with it?
Old Dec 14, 2009 | 08:59 PM
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
wow!!! VQ ftmfw
Old Dec 14, 2009 | 10:12 PM
krazy6's Avatar
150 shot can be done reliably if you know what you are doing.
Old Dec 14, 2009 | 11:33 PM
With proper safety measures and tune, it's definitely less stressful on your engine than other types of F/I, and makes for a mild street car when not in use. Ultimately with TPS, window and A/F switches added in with some general caution, it's very unlikely to "blow up" anything with nitrous unless you're spraying way too much for what your bottom end can handle. Thanks to Jime and some other pioneers, we know the 3.5 is reliably capable of handling a 150-200 shot.
Tuning is the key, as in pretty much every other case.
Old Dec 15, 2009 | 12:30 AM
505max94se's Avatar
Impressive numbers!
Old Dec 15, 2009 | 02:17 AM
JonBlz's Avatar
a.k.a. STuNtMAN
nice nice
Old Dec 16, 2009 | 01:48 AM
you know whats interesting is i entered those jets and its equivalent to about a 175shot according to dynotune nitrous calculator.
as of right now i dont really have a tune or any sort of safety with it. It was cold so i got away with spraying a big shot. I didn't want to bring it to redline because a lot of people were there also i was afraid of clutch giving out. The nitrous was also spray at 900psi.
I have the run file just my scanner is not working right now. The cars hp and tq is about 1:1. The tq was like 391wtq or something like that.
Im getting a utec next week, im curious to see what it will do for me all motor. Best i ever ran was 13.4@104.6 2.1 60' on 275/40/17 MT ET Streets which is probably 26+ in diameter on 22lbs mustang rims.
It sees more street than track.
Old Dec 16, 2009 | 01:48 PM
505max94se's Avatar
.62N/.35F is good for 150 hp at the wheels and 175 hp at the crank. NX recommends .62N/.35F for a 150 shot. Some manufacturers rate their jetting in chp and others rate their jetting in whp. I'm using the same jetting as you.
Old Dec 16, 2009 | 01:53 PM
If only the weather could get better. Can't even dream of going WOT N/A let alone with my current 120 shot. But a 150 shot. When is summer coming back?!
Old Dec 16, 2009 | 03:28 PM
505max94se's Avatar
I've sprayed it couple of times recently and I had really bad torque steer in 3rd.
I would really like to go to Pacific Raceways this next season with you and couple of boosted 4th gen guys (mastercater7 and Nozama). It would be awesome to run some other comparable cars at the strip.
Old Dec 16, 2009 | 05:12 PM
krazy6's Avatar
I wanna know what your car runs when it hooks! Should be good!
Old Dec 17, 2009 | 06:05 PM
It did hook. He just didn't launch it aggressively enough.
Old Jan 15, 2010 | 06:12 PM
sahwan's Avatar
nice power
me like it
Old Jan 15, 2010 | 09:11 PM
QNO_A32's Avatar
is this the car from b20 ?
Old Jan 17, 2010 | 11:13 AM
Grand_hustle17's Avatar
257 NA is very impressive
Old Jan 17, 2010 | 02:38 PM
Yes it is
Old Jan 17, 2010 | 02:40 PM
I ran the car for 40mins straight before the dyno to warm up the bottle, so it would probably see 260. Also dyno dynamics read lower than a dynojet.
Its in the 270 territory on a dynojet
Old Jan 17, 2010 | 05:07 PM
I'll agree when I you show us 108+ traps.
Old Jan 17, 2010 | 10:05 PM
Gemner's Avatar
i hope you mean 108 traps on the bottle because he wont be trapping 108 with 260 whp
Old Jan 17, 2010 | 10:08 PM
QNO_A32's Avatar
i was there when you locked it up with my boy stitch with the black rsx. i had the black 4th gen. i have a blue 5.5 6speed now. havent seen the car around since then really. you guys have any parts for a 5.5 fs? very nice numbers by the way.
Old Jan 20, 2010 | 03:19 PM
He said it would be 270whp on a dynojet. Jaypee ran 109 traps with slightly over 270ish whp on a dynojet and likely a lighter car and very good shifting. I am just doubtful of an untuned N/A full bolton 5.5 is a 270whp car matching one with a few more mods and tune.
Now on nitrous I wouldn't expect anything less than 115 with 390+ whp!
Old Jan 20, 2010 | 05:34 PM
Gemner's Avatar
the majority of people making 260 or so HP arent trapping higher than 105 or somewhere around that, I think expecting him to trap 108 is the same as expecting him to be a great driverm which IMO you really just cant do
Old Jan 20, 2010 | 05:41 PM
streetzlegend's Avatar
Yeah I agree, i was at 105-106 with just about 280hp years ago, full weight, and auto, with 390 he'll be flying
Old Jan 20, 2010 | 05:45 PM
perkman87's Avatar
great another Epic win towards the persuasion of nitrous in my vehicle.
lol
Old Jan 20, 2010 | 06:40 PM
I'm not a great driver, I have 100 lbs on Jaypee's race weight, and my car has done mid 107 traps N/A. I can not imagine mine putting down much over 270whp, if it is even makes that much. Also remember SR20DEN with his 108 traps on 270ish whp.
It doesn't take an amazing driver to get good traps, just one who can shift quickly. I'm sure Jaypee or travis (spec V travis) could jump in my car and pick up 1-2 mph over me, though!
That said, I don't see why it's unreasonable to expect a (supposed) 270whp car to at least match mine. Sure, JP and I are tuned with more mods than him, but hell apparently he's putting down at least as much power as JP is (if only it were a dynojet... *cough*)!!!!
I'm not contesting the 257 whp number, just the 270whp claim.
Did you ever get graphs? Just interested in seeing the curve on your N/A run.
MaximaDrvr
Aug 19, 2015 08:20 PM
