Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
trick shift for 90 auto max?
Old Jun 27, 2003 | 07:14 AM
MAXMAN91's Avatar
should i use the trick shift atf in my auto tranny. i was planning on going up to the track this weekend. should i use the regular or the synethic kind?
does it help at all?
Old Jul 3, 2003 | 07:14 AM
MAXMAN91's Avatar
anyone? also i saw something called wet wetter for our raditors will this help keep things cooler?
charlie
Old Jul 4, 2003 | 03:00 PM
Dave Holmes's Avatar
Don't know about the Trick Shift.
Water Wetter (by Redline) is reportedly good stuff to help the coolant dissipate heat better. Personally, I use it as a little added insurance, but couldn't tell you how much it lowers temps. You will not see any difference in your temp gauge. Check your coolant ratio for proper cooling. Unless you live in the Arctic Tundra, more than 50% antifreeze shouldn't be needed. Antifreeze is terrible at dissipating heat, so the lowest ratio for your weather conditions, the better for heat dissipation (living in Louisiana, I use 30% antifreeze/70% water all year). There was a thread not too long ago about a member having a heat problem, maybe by BigDogJonx (sp?) that can give you more info.
Dave
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
MaxLife17
Sep 8, 2015 02:36 PM
