Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
*Question regarding the installation of a new oil drain plug washer...*
Old Mar 14, 2007 | 06:35 PM
  #41
peace's Avatar
Originally Posted by dannodotcom
I have been doing oil changes on my vehicles for 30 years and have never replaced a washer, never had oil leak from the drain plug either. Had my Max (2000 SE) for 7 months now and have done 2 oil changes and have not replaced the washer and there is NO leak. When I do an oil change, I make sure to clean both mating surfaces (plug and pan). If a leak develops there then maybe I'll change my position on changing washe
x2 I only change the crush washer when I see a leak, which is rare.
Old Oct 31, 2007 | 05:10 PM
  #42
wyche89's Avatar
I have been doing oil changes on my vehicles for 30 years and have never replaced a washer, never had oil leak from the drain plug either. Had my Max (2000 SE) for 7 months now and have done 2 oil changes and have not replaced the washer and there is NO leak. When I do an oil change, I make sure to clean both mating surfaces (plug and pan). If a leak develops there then maybe I'll change my position on changing washers.http://forums.maxima.org/newreply.ph...ply&p=2484781#
Dannodotcom
changing the washer isn't a big deal.. i've never had a leak.. change it if you want, but if not... YOUR CAR WILL EXPLODE!! j/k.. nothing will happen.. no bid deal
Old May 8, 2008 | 03:22 PM
  #43
Kryogen's Avatar
They sold me one but I wasnt sure how to install it so I just used the one that's on the plug already. It's a thick 1/16 copper washer. The one the dealership sold me is a thin, donut with no external side shaped copper washer, that had a notch in it. Really not sure how to install it.
Any of you have a solid copper washer like that?
Old May 8, 2008 | 03:59 PM
  #44
VEvolution's Avatar
I miss my VE
Yeah they are all the same. It's not hard to figure out how it goes. Common sense works here. Just imagine which side up(crushed) would serve as a better gasket. Which ever you decide will do the trick
Old Feb 15, 2009 | 01:24 PM
  #45
Rob_0126's Avatar
Thinking about this, could it have to do with vacuum in the engine?
Heres what I mean: Ive noticed on the VQ, if you remove the oil cap, the idle drops, signifying vacuum change.
My 3vz-fe does this very pronounced.
So the question would be, does the gasket have a vacuum seal purpose.
Old Feb 15, 2009 | 03:23 PM
  #46
dannodotcom's Avatar
Rob_0126
I understand what you are saying, but the valve cover where the oil cap is has a slightly negative air pressure due to the PCV valve which is why when you take off the oil cap when the engine is running, the engine will stumble a bit, I think there are sensor(s) that get messed up if you do that too. The oil system, below the heads, has a pressure of about 30-70 PSI, so is kind of separate from the valve cover, even though some oil does get forced into that area. The oil plug on the oil pan on the bottom of the engine must be a tight enough seal to prevent oil from leaking out, it doesn't have to stop air getting in. So, the answer to your question is no.
Old Feb 15, 2009 | 05:56 PM
  #47
Rob_0126's Avatar
Rob_0126
I wasn't sure, just a thought. The camry was the first engine I saw that taking the oil cap off affected the vacuum. Ive worked on chevys mostly.
Does it do permanent damage to sensors if the cap is off for a short time, or does it just trip um?
Old Feb 15, 2009 | 09:47 PM
  #48
Nope, won't do any damage to sensors, probably won't even trip them, unless you drive off without the oil cap. Then you would probably see a check engine light within a few minutes, not sure how well the engine would run either.
Old Mar 11, 2009 | 02:37 PM
  #49
NIKV69's Avatar
My local dealer Rothrock Nissan charge $2.40 each. That was insane!!!Ya, Bob Moore Nissan here in Norman charged me $1.25 each and I thought that was a bit steep.
Get your parts from nissanpartsonline, great prices and free shipping.
I change my every oil change. Cheap insurance against leaks.
Old Jul 2, 2010 | 05:55 PM
  #50
joebangaa's Avatar
I wanted to chime in here even though people stopped posting over a year ago.
With all due respect to to Bill, I completely disagree with the statement that the FLAT end of the washer butts up against the drain bolt. The FLAT side was clearly designed to meet the oil pan. Having the flat side against the drain bolt can cause potential leaks. As we all know, the copper washer is designed to crush when the drain bolt is installed. If the flat side were to face the bolt head, the rounded side would end up being crushed over the threads of the drain plug. This might make very little sense when stated in words, but all one has to do is actually look at a drain plug and crush washer and it will all make sense. Having the flat side face the bolt makes it easier to remove the used washer from the drain plug because it'll thread off nicely, but it is incorrect and I'm certain that any Nissan engineer would agree with me.
Old Aug 14, 2011 | 06:44 PM
  #51
Kryogen's Avatar
i dont use one. never leaks.
Old Jun 1, 2014 | 12:33 AM
  #52
Nismo_Pilot's Avatar
First, let me get this out of the way for fakie. "I just bumped a 3 year old thread, I must be a moron".
Alright, now to information. While most of you have changed the oil on your Max 10-20 times, I have changed the oil on over a thousand Nissans. Replace the damn crush washer, every oil change. Why? Because it is there to prevent leaks. Sure you can go without doing it. But you have to tighten the bolt more to get the same seal quality, risking warping the pan, stripping the bolt/pan, etc. Using a new crush washer will allow you to just seat the bolt until it stops turning easily and another 10° of rotation and you are golden. If you re-use the old washer and do get a leak, goodluck getting the old one off the bolt after it gets welded to the head from multiple torquings. I have other techs at the shop who dont replace them every time and I can always tell when I get a car they changed the oil in last. If you are worried about a dollar per 3k miles, go buy a honda, they use non-crush washers.
PH98I30
Jan 9, 2025 08:08 AM
Cotozic
Jun 28, 2017 08:01 PM
maxinout93
Aug 20, 2015 02:17 AM
Superbform
Aug 11, 2015 08:10 PM
kirkhilles
Aug 8, 2015 10:53 AM
