Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
GL 4 vs GL 5
Old Dec 29, 2003 | 06:38 PM
maxfun's Avatar
GL 4 vs GL 5
What's the difference between GL 4 fluid vs the GL 5 fluid. Also how does mobile 1 tranny fluid compare to Redline or Amsoil. I just changed my fluid and used Mobile 1 (which is a GL 5). I have always used this in all my cars because I've heard it is the best. Any thoughts.
Old Dec 30, 2003 | 07:57 AM
CCS2k1Max's Avatar
There's a sticky three or four threads above this one, but if you can't see it, here's the link.
http://forums.maxima.org/showthread.php?t=225766
Old Dec 30, 2003 | 11:14 AM
johnny2kgle's Avatar
Mobil 1 will probaly be okay. It is the Valvoline and others that I definately would not use.
The conventional GL5 gear oils have friction modifiers and additives that will "eat up" the synchros in the gears. Since Mobil 1 75w-90 is fully synthetic, it does not need the friction modifiers and other excessive additives to get the job done.
Give Mobil's tech line a call to get their answer.
Old Dec 30, 2003 | 12:11 PM
spirilis's Avatar
Website regarding Mobil 1 75W-90 Synthetic gear oil:
http://www.mobil.com/USA-English/Lub...rLubricant.asp
Excerpt:
"Mobil 1 Synthetic Gear Lubricant 75W-90 combines wax-free synthesised hydrocarbon base oils and a specially designed extreme-pressure, limited-slip, sulphur-phosphorous additive system..."
sulphur-phosphorous additive? I believe it is the sulfur-based additive in GL-5 gear oil which corrodes brass synchros...
Old Jan 1, 2004 | 06:45 PM
iwannabmw's Avatar
If you're going to bother to switch to synthetic, use Amsoil or Redline. In the gear oils, you'll get much more for your money.
A conventional GL5 fluid has roughly double the amount of EP additives as a GL4 fluid does. These specs are not backwards compatible and a conventional GL5 fluid in a Maxima transmission can destroy it. Both Amsoil's and Redline's formulations are safe to use.
