Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
brake fluid and bleeding
Old Mar 16, 2004 | 09:20 AM
maximaisokay's Avatar
Anyone got instruction of bleeding? And what is the best brake fluid?
Old Mar 27, 2004 | 01:06 PM
2002 Maxima SE's Avatar
I'm wondering what kind of brake fluid to use as well.
As for bleeding:
1)Open the brake fluid reservoir. Pump the brakes a few times, attach a length of hose to the bleeder screw, put hose in jar, and then unscrew bleeder screw on caliper 1/4 to 1/2 a turn.
2)Have someone in the car push the brake pedal almost to the floor.
3)Retighten the screw before brake pedal reaches floor.
4)Get ready to add brake fluid.
5)Have the person in the car release the brake.
If you get the speed bleeders you won't need the second person or half these instructions.
Old Mar 31, 2004 | 12:35 PM
where can i get the hose?
Old Apr 13, 2004 | 11:22 AM
ThurzNite's Avatar
Whatever method you use, don't use the 1-man-pump thing. It works by hooking a tube from the device to the bleeder, pumping to create a vacuum, then opening the valve letting vaccum pull fluid out. It's not a good idea cuz if your seals are cracking/drying, you'll pull air into the system.
2002 Maxima SE's method is my choice... just remember to pump the brakes to create pressure, then hold down while releaseing the valve. Sometimes the pedal wont' come back up after bleeding... just pull it up, pump, and you're ready to go again.
Jae
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
