Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
People who have flushed dino ATF with syn. Thoughts?
Old Apr 2, 2004 | 05:53 AM
zazon's Avatar
I have a 99 auto with 60k miles on it, it has had two flushes done on it with the regular stealership method. Im considering seriously doing a full flush with some syn (probably amsoil, read a lot of good things about it). I ready the sticky about this, but havn't seen that much talk about pricing on something like this. Im probably not going to drop the pan, just perform the method lined out in the 'faq' section. Someone mentioned using 2 boxes (24 quarts) of amsoil? Is that overkill? That's gonna be pretty expensive... would it be feasible to do the flush with some cheaper syn, then do the fill with the amsoil? That's about the only other thing I can think of to knock the price down a little bit... Give me your input, thanks org.
Old Apr 2, 2004 | 06:17 AM
Jime's Avatar
10 qts is sufficient if you do it yourself as per the faq.
Old Apr 2, 2004 | 06:30 AM
zazon's Avatar
forgot to mention the hayden cooler... ill probably be looking at using a whole case then, right?
Old Apr 2, 2004 | 06:35 AM
iwannabmw's Avatar
While I'd love to sell you two full cases of ATF, it's way more than you need. You should be able to get by with one case as long as you don't waste a lot in the procedure.
If you're interested in discounted pricing on Amsoil, shoot me a PM.
Old Apr 2, 2004 | 06:47 AM
zazon's Avatar
awesome-- i'll let you know when/what I decide to do. I have a couple othe 60k maintenence things to do first but the flush is coming up pretty soon.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Dec 12, 2015 09:39 AM
Maximeltman
Sep 28, 2015 07:19 PM
