Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
ATF change in my 1990 maxima
Old Jun 10, 2004 | 01:18 PM
pinkfloyd's Avatar
After I unbolt the pan and drain all the old ATF where do I poor the new ATF in.
Thanks.
Old Jun 13, 2004 | 07:02 PM
Kalohe's Avatar
After the pan is reassembled, get a long funnel and add the new fluid via transmission dipstick tube. The haynes manual states that you should measure the amount of fluid that was drained, then add the same amount. DO NOT OVER FILL!! add a little fluid then check the level...
Old Jun 14, 2004 | 07:59 PM
pinkfloyd's Avatar
thank you very much. I really need to buy a haynes manual for my DD.
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Flores94
Aug 11, 2015 12:53 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
