What about the engine block drain plug?
Everyone is always talking about flushing the cooling system by draining the rad, filling it with distilled water, running car with heat on, cooling, draining, and repeating.
My question is, what if, like my Chilton's manual says, you removed the engine block drain plug to drain all the coolant from the block. Would you then still need to flush the system, or would all of the coolant be out?
to me, thats not worth F-ing around with...first of all there too hard to get to, Y-pipe will need to come off, and second there really isnt alot of coolant in there any way..
Drain the radiator, get a garden hose and trickle the water out of the hose, Plug the radiator back up and run the car till all of the water coming out of the car is Non-Green
-matt
-matt
sctludwig
Sep 1, 2022 01:32 PM
6spd4dsc
Mar 4, 2016 05:19 PM
markevans999
Sep 10, 2015 04:29 PM
