Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
AC Recharge
Old Jul 12, 2004 | 03:56 AM
Matto357's Avatar
AC Recharge
How hard is it to recharge the AC system on a 2k max? I'm probably gonna do this today and want to try one of those do it yourself kits. Do they work well, anything I should know about?
Old Jul 12, 2004 | 05:23 AM
DanNY's Avatar
Ad·min·is·tra·tor
the ac system should be 100% sealed. you shouldn't have to recharge it unless you have a leak. in that case find the leak before you add more R134a.
Old Jul 27, 2004 | 06:25 PM
panda_1's Avatar
thats understandable but dont you need a recharge every once and a while on all cars.
Old Jul 30, 2004 | 09:55 AM
BigAl's Avatar
Eventually some refrigerant leaks out. If it's every yrear or two, then there is a significant leak. Also keep in mind that some refrigeration oil usually leaks out with the refrigerant. If you keep topping off a leaky system and don't add oil, it's going to wreck the compressor. If you add too much oil, the system efficiency goes south.
If you take your car to a mechanic, they can use a refrigerant sniffer to find even tiny leaks and recommend what to do.
Matt93SE
May 24, 2019 02:58 PM
BkGreen97
Apr 2, 2016 05:47 AM
maxima297
Sep 24, 2015 01:18 PM
silvermax2k2
Mar 17, 2003 08:16 AM
Miasma
Aug 29, 2002 02:39 PM
