Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Water Wetter ??
Old Aug 2, 2004 | 12:19 AM
matty's Avatar
Water Wetter ??
Does your Redline water wetter mix with your coolant or not ?? I put it and now I have dropps of red marks on the coolant...Im assuming its the water wetter I just wanna make sure its not Oil
anyone use Water wetter and in your over flow tank do you see droplets of it
-matt
Old Aug 2, 2004 | 07:26 AM
MaxSpeedSE's Avatar
Well if you use water wetter your supose to drain a little coolent when u add it so it dosent end up in your overflow tank. But the best way to run it is drain you’re coolent and run 100% water and a bottle of Red line water wetter. Only in the summer tho, not in the winter it will frezz up
-Chris
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
