Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Oil/Lub job
Old Sep 7, 2004 | 05:06 PM
Progress's Avatar
It's business time.
Oil/Lub job
I want to get my oil changed to synthetic and my gear lube changed also, although I have no access to ramps or jacks. I've heard that ideally the car should be level for the gear lube filling so taking it to a shop should be the best alternative to doing it myself. My question is, is there somewhere I can take it where they would do the oil/lube change using my fluids? I don't want to get stuck with valvoline again I want Amsoil gear lube and Mobil 1 syn.
Old Sep 8, 2004 | 07:27 AM
SkoorbMax's Avatar
Any quick lube place should accept your fluids if you talk to them. In terms of filling the tranny on a flat surface, if you use a jack and jackstands you can pump it up, put it on the jackstands, drain the fluid, fill it up until it just comes out of the hole, then lower it until it's flat, allowing the rest to come out, then screw the fill hole back up and you're good. If you have a garage/driveway, it's a great time to learn how to do this stuff instead of paying somebody else
Old Sep 8, 2004 | 09:04 AM
Progress's Avatar
It's business time.
I live in an apartment building and the only jack I have is the one in the trunk. I guess I could do it at my girlfriends parents house. Her dad might want to help me also.
James92SE
142
Jan 2, 2024 09:23 AM
doctorpullit
Mar 29, 2016 11:08 AM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
