Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Motor Oil Question
Old Sep 15, 2004 | 07:49 AM
Kolyan's Avatar
Motor Oil Question
I did an oil change on the gas station and instead of 4.2 qt. the guy put 6 qt. in. so he ended up draining everytning and then pouring the oil back in. 1.5 qt. was left that he put into original Mobil1 bottles and gave me. here is the thing that i am conserned about: the NEW oil that was out of motor was already black color (like old). i compared it to new bottle of Mobil1 10-30 Syn. oil, and my oil was twice as dark. Is this normal? btw. my motor oil was also Mobil1 10-30 Syn.
Old Sep 15, 2004 | 08:09 AM
SkoorbMax's Avatar
Oil will darken quickly, but if you pour it in and maybe run the car for a couple of min, and then the new oil is well and truly black and dirty again, well it really shouldn't be.
Old Sep 15, 2004 | 12:42 PM
Kolyan's Avatar
well....the car was running on new oil maybe 5-10 minutes and when the guy at the shop drained it, it was already noticably darker then the new-opened bottle (I checked later side by side)
Old Sep 15, 2004 | 08:47 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
When you drain your oil, some of the dirty oil remains in the engine.
Your fresh oil probably mixed with the dirty oil that remained in your engine, causing the new oil to darken. I'm less concerned about that than I am about the guy pouring the oil back into your engine...although the oil was fresh, I hope the drain pan he used to collect the oil was clean. I think I would have poured the oil thru a coffee filter or something just in case...
Old Sep 15, 2004 | 10:04 PM
Kolyan's Avatar
i did see him cleaning the pan before draining the oil. i'm concerned that he didn't even do the oil change and that's why the oil was black. i was gone at that time, he might've just installed new filter and emptied my bottles. (i heard some machenics do that)
Old Sep 16, 2004 | 11:16 AM
schmatt's Avatar
Or maybe he didn't replace the oil filter. Did you check to see if it was a new one? The oil filter will hold about 0.5qt of oil. If you don't change it, that will mix with the new oil too.
Old Sep 16, 2004 | 12:41 PM
Kolyan's Avatar
i don't know......the oil filter was the same brand, i don't know if it's new or not. ah.....i''m just gonna have to find some more time and do another oil change. it's just too bad i have to spend another $35-40 bucks on oil again.
Old Sep 16, 2004 | 02:05 PM
Mizeree_X's Avatar
Getting back to his roots
A 5qt jug of Mobil 1 is $19.xx at Wal-Mart.
AcuraLegend
Oct 17, 2016 08:47 PM
kjlouis
Oct 3, 2015 05:29 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
