Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Automatic Fluid Type?
Old Oct 7, 2004 | 10:51 AM
SE2002's Avatar
I have a 2002 SE and want to change my trany fluid over to syenthtic. Has anybody done this? How hard was it? Did it make a difference? Thanks
Old Oct 7, 2004 | 12:36 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
very easy to do a drain and refill. just remove the bolt and let it drain for a while. refill with whatever syn atf you want, i prefer mobil 1 atf. it is available in alot of stores and is reasonably priced. as far as making a difference, i noticed no difference in shifting but it was easier to move the shifter from gear to gear. the main reason i did it was for the lower operating temperatures.
Old Oct 7, 2004 | 03:02 PM
wbstru's Avatar
Ive been useing moble 1 atf and iam very happy. Its hard to notice any different feel but your trans will last alot longer. Under normal use
Old Oct 7, 2004 | 03:23 PM
louisvuitton500
I just got it done couple days ago. I think u got to use a machine that can replace 100% of the fluid. It cost me like $225 at Pepboys. I feel no difference at all. Even from shifting gear to gear. Just hope my tranny will last longer......
Old Oct 7, 2004 | 08:45 PM
GimmeTorq's Avatar
Mobil 1 here too. Good stuff. But Amsoil Universal seems to be a better match, since it seems Nissanmatic D4 is a Highly Friction Modified Transmission Fluid. A Dexron III fluid like Mobil 1 is also compatible, based on the owners manual.
I may try adding Lubegard's HFM Supplement to Mobil 1 in my next drain 'n' fill to see if it makes a difference.
Old Oct 8, 2004 | 11:32 AM
pruizgarcia's Avatar
I use the Mobil1 ATF and also added about 6 oz of the Lubeguard HFM. Shifting is real smooth.
Pedro
Old Oct 8, 2004 | 11:07 PM
GimmeTorq's Avatar
Pedro
awesome!
Old Oct 9, 2004 | 09:03 AM
Love_00_Max's Avatar
Pedro
ATFs are a complex combination of additives to meet certain specs. I doubt any HFM would make a difference, becoz if it did all ATFs would carry that while getting bottled -- my suggestion would be to change the ATF and not add any of these OTC additives, I doubt they have done any analysis if this is added to any ATF and what has changed in the original spec... My suggestion is to just flush the ATF with some high quality OTC DexronIII ATF like Pennzoil, Valvoline, Chevron and if you like to spend bucks go for those high end Mobil1/Amsoil syn ATFs.
Old Oct 9, 2004 | 12:54 PM
Virus's Avatar
The only way to ensure a complete fluid change is by taking to a shop and having them flush the system. It's only like $75 if you have your own fluid. I use Amsoil ATF.
Old Oct 9, 2004 | 08:28 PM
Bl_asd's Avatar
Could someone post a picture of drain plug of tranny? i can't find it...duh...
Old Oct 10, 2004 | 03:18 PM
talkinghorse's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
It's underneath the car, in the middle of the transmission pan...the bolt is recessed a little. You can't miss it...
Old Oct 10, 2004 | 06:40 PM
Bl_asd's Avatar
...so i have to juck up my car?.....sigh..hate to do that, last time it almost crashed on me..
Old Oct 10, 2004 | 07:28 PM
sloppymax's Avatar
get some $20-25 ramps from advance or pep boys. block the back wheels and you are fine. only max that has been unable to get up mine had teins. all other lowered cars had no issues.
Old Oct 12, 2004 | 05:06 AM
Bl_asd's Avatar
so how you jack up ur max with ur teins? just up 1 side with normal jack and put the ramp on the other side and jack up then switch jack to ramp?
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
