Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Automatic Trans Fluid Capacity?
Old Jan 28, 2005 | 06:01 AM
dmirocha's Avatar
Can anyone give me a ballpark as to how much fluid my 96 SE automatic transmission holds. Both the owner's manual and the Haynes manual states that the best way to determine quantity is see how much is removed.
I just need a ballpark so I know how many quarts to buy.
Old Jan 28, 2005 | 06:13 AM
mzmtg's Avatar
Minister of Silly Walks
It's about 10 quarts.
Old Jan 28, 2005 | 09:28 AM
schmatt's Avatar
It's 10 quarts, but you will probably need about 12 if doing a flush.
Old Jan 28, 2005 | 12:43 PM
UncleMax98's Avatar
About 4 - 5 quarts for a drain and fill.
Old Jan 29, 2005 | 11:24 AM
thephatOne's Avatar
my mechanic did my flush (dropped pan etc...) and he only put 5 qts, but he checked the level and showed it to me and it seems fine, is this a good or bad thing...oh my tranny still slips from time to time, when its cold and if i have a full car. Another thing is maybe because i waited 113k miles to do my flush. (i live in los angeles so lots of stop and go driving)
Old Jan 29, 2005 | 01:08 PM
schmatt's Avatar
Are you sure he flushed it? If he only put 5 qts in, that means he just drained the pan and cleaned it out. It should've taken 10 qts for a flush.
Old Jan 29, 2005 | 01:52 PM
thephatOne's Avatar
hmm, well since its still slipping he said hell drain it again and then fill it, that should help right?
user 11122324
42
Jul 18, 2022 03:35 PM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
