Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Will changing back to dino help my leak?
Old Apr 11, 2005 | 08:07 AM
KCMaxima98's Avatar
Car has about 90K on it. I use mobil 1 5w-30 and the oem filter. The previous owner also used synthetic although I doubt it was mobil 1. Anyway my small seepage from the rear main seal turned into a full blown leak within the past couple of weeks. The stealership wants $1K to fix the seal which means that a local shop will probably want 600-800 to fix it. I can't afford that right now. I also can't afford to keep pouring in this expensive synthetic oil only to have it leak out on my driveway. Would changing to a dino oil slow the leak at all? Is there any negative effects from going from synthetic back to dino oil? I have heard that it isn't good to stop using synthetic once you start using it. Is that BS?
Old Apr 11, 2005 | 11:34 AM
bladerunr's Avatar
There are no problems switching back and forth. I don't think anything will help your problem. If dino sludge were to help your problem it would take many thousands of miles. To save money you may want to switch to a cheap, heavy grade dino.
I've used Restore for small leaks and it worked fine. Unless a mechanic can recommend something you may be screwed.
Old Apr 12, 2005 | 12:27 PM
KCMaxima98's Avatar
So if I use a 5w30 syn now should I switch to a 10w30 dino...or heavier? Or would a 10w30 syn leak more slowly?
Old Apr 12, 2005 | 04:39 PM
johnny2kgle's Avatar
Try some auto rx with the dino du jour.
http://auto-rx.com/pages/sealleak.htm
This stuff works and if does not then you can get a refund.
Old Apr 13, 2005 | 05:18 AM
deezo's Avatar
Why not just fix the problem? Chances are it's the rear valve cover gasket. Buy the gasket set (around $50) and install it.
Old Apr 13, 2005 | 06:31 AM
nite-stalker's Avatar
heavier dino oil might help, but after a while it will leak again. fix the problem.
Old Apr 16, 2005 | 04:45 PM
KCMaxima98's Avatar
Im 99% sure it is the rear main seal. Stealership confirmed that too. I wish it was a valve cover gasket. I would have fixed it already if that was the case. I don't have the money right now to fix the engine seal. Im getting married next month.
Old Apr 22, 2005 | 06:15 PM
KCMaxima98's Avatar
The dealer was wrong. Im leaking MT fluid not oil. I guess I have bad bearings in the trans. It leaks from where the axle comes out of it, kind of close to the seal I thought was bad. I also thought that because the car does use some engine oil too...like a quart every 3000 miles or so. Anybody had their 4th gen tranny rebuilt? What did it cost and did it last? Not really a fluid/lubricant question but the thread is already here...
Old Apr 22, 2005 | 07:25 PM
BK1's Avatar
BK1
Hello
Using synthetic doesn't make your car leak. It just reveals the problems the car has already. If you car is leaking, get it fixed. Switching back to dino won't help.
Old Apr 22, 2005 | 09:30 PM
kcryan's Avatar
another vote for auto-rx
JRod28
Dec 29, 2023 09:56 PM
egali045
Aug 16, 2015 01:19 PM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
