Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Auto Tranny Flush Question
Old Apr 30, 2005 | 10:20 PM
PhillyDonut's Avatar
I need to do a auto tranny drain and fill and was wondering if anyone has the link to the how-to remove tranny drain pan and cleaning the tranny screen with part number for screws (I think). I've looked through the stickies, but can't find it.
Thank.
Old Apr 30, 2005 | 10:39 PM
ThisMaxIsTight's Avatar
hey man...you should get a tranny flush, dont just drain and refill, draining only gets less than 1/2 of the fluid out of your tranny, you need to get a flush and get all the old nasty fluid out of there, its really important...go to aamco, I went there a few months ago and they were running a special for 99 bucks, its the aamco on bustelton ave...the guy there was telling me that after a certain amount of miles that the fluid becomes useless after being heated up so many times, and then there is no fluid to protect your tranny parts...plus-once you get it, then you can get it for free once a year!...banging deal...good luck
edit: just so you know, its as a crazy amount of work to drop your transmission pan, I had it quoted at well over 200$...just get a flush
Old Apr 30, 2005 | 10:51 PM
CreativeDesignz's Avatar
Its easy as hell to drop the pan it took me 15 minutes in and out. its 21 bolts i believe. take them out pull on the pan (be careful it will have fluid in it still) clean everything out. put some permatex on the surround of the pan and bolt it back up.
Old May 1, 2005 | 06:39 AM
njmaxseltd's Avatar
All you need to know is right in this thread.
http://forums.maxima.org/showthread.php?t=149056
Old May 2, 2005 | 09:42 AM
Thanks! that's the exact thread I was looking for
sctludwig
Sep 1, 2022 01:32 PM
pktaske
May 6, 2016 07:49 AM
Violator
Sep 9, 2015 10:14 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
