Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Nismaticj????????????
Old May 3, 2005 | 02:57 PM
NOCturnalI30's Avatar
Is nismaticJ any good tranny fluid i hurd thats wat infiniti uses in there i30s. I wanna just to a drain and fill since i have soo many miles. what do you guys think
Old May 3, 2005 | 04:19 PM
Love_00_Max's Avatar
NissanMaticJ is a special ATF (FM though) with no OTC substitutes for the fluid (could be one of those high quality synthetic fluids with additional friction modifiers). I bet this stuff is more expensive compared to MaticD (which you can formulate with OTC DexronIII using some friction modifiers).
If the manual says MaticJ then you are stuck -- you need to pay the big bucks and get it from Nissan. BTW, if you are past warrantly, who cares use Chevron ATF + Lubegard black FM becoz the Maxima and Infiniti cars look alike for the most part -- doubt the tranny's are any different, except that I30's shift very well. Check up the transmission model and make and take it from there....
-- Checked the web and there seems to be some alternative to this goofy ATF. Castrol doesn't sell this in the US (atlest there is no mention of such a fluid in its website).
"Currently available exact equivalents to NISSAN Genuine ATF Matic Fluid J are Castrol Transmax J or IDEMITSU ATF HP."
Old May 12, 2005 | 07:01 PM
jdmmax's Avatar
nissan will state on the trans oil dip stick if the tranny takes anything other than maticD/dextronIII.
