Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Flush or transmission kit?
Old Sep 29, 2005 | 11:22 PM
athlon omega's Avatar
I have 153k miles on my 95 auto maxima. I noticed that the shift between 1st and 2nd gear have been hard. It's been a while since the transmission was serviced, but it was a flush at around 120k miles. I then had a mechanic install a transmission cooler. I'm not sure if he drained the fluid, but he toped it off. I bought the transmission kit from NAPA. My question is do I need to flush the transmission or have the kit installed?
Old Oct 6, 2005 | 03:40 PM
jessefrank's Avatar
You already bought the trans rebuild kit? I did the DIY return line flush on my 03 auto at 32k and noticed alot of shavings/really dark color. Since that experience I will definately flush the tranny at least every 30k. I suspect that with your older tranny it probably needs the fluid flushed. If you DIY the flush I shouldn't cost you that much( even with M1 syn tranny fluid it cost me less than $50 for the fluid[+26 for the pan gasket]). In that case it should cost alot less than having a rebuild done, and if it dosen't solve your problem you are only out $30-$75.
Old Oct 6, 2005 | 06:40 PM
I bought the kit from NAPA for like $16 a month ago. I'm not to familiar with flushing the tranny. I would do this after I install the kit?
Old Oct 7, 2005 | 04:53 AM
jessefrank's Avatar
For $16 you more than likely didn't get a rebuild kit. There are several how-to's on this board with detailed instructions on flushing the tranny yourself(sorry I don't have time to research the exact threads).
Old Oct 7, 2005 | 06:49 AM
Bobo's Avatar
I'm no expert on automatic transmissions as I have a 5-speed. If you had the tranny flushed @ 120K, it is due for a drain and fill at 150K. I am not sure what you bought.
If it was my car, I would have done the following:
30K drain and fill
60K flush/service
90K drain and fill
120K flush/service
150K drain and fill
then at 180K flush/service etc.
In other words do a drain and fill every 30K, followed by a flush/service at 60K intervals.
At a minimum, you are now overdue for some kind of tranny fluid service.
user 11122324
42
Jul 18, 2022 03:35 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
