Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
View Poll Results: Is this plan good?
Yes
100.00%
No
0%
Voters: 2. You may not vote on this poll
Good or Bad?
Old Dec 22, 2005 | 10:31 PM
IlyaK's Avatar
The Golden One
Good or Bad?
Okay...I have a 1997 GXE with 164,xxx kmi on it...I'm in the process of bringing the engine and such up to speed because the previous owner - my older brother - didn't maintain it. This is what I plan to do:
  • Replace coolant with Toyota OEM Anti-Freeze (red) - 10 qts
  • Use Amsoil or Mobil 1 ATF for Transmission - 10 qts
  • Use Amsoil or Mobil 1 ATF for Power Steering - 4-5 qts
  • Change to Mobil 1 SyperSyn 5w/30 - 4.5 qts
  • Change to Nissan OEM 15208-9E000 Oil Filter
  • Clean out tranny pan and purchase:
    • New gasket
    • New drain plug
    • New "Screen" (filter)
    • New Pan Bolts (21)
From what my next project is...will this bring my engine back up to speed? Can or should I do better? Do I need to purchase more than the amounts I have listed? Let me know if I should change anything. Thanks.
Old Dec 22, 2005 | 10:54 PM
OHH NOES's Avatar
6spd Swapped
If he didnt maintain it you can also try seafoam or Auto-Rx before your next oil change. I personally havent tried either but a lot of people swear by them
Edit: You can also check your air filter.
Old Dec 22, 2005 | 11:56 PM
IlyaK's Avatar
The Golden One
Sorry...I forgot to mention that I did use Gumout Regane about 3 weeks ago...changed my air filter, cleaned the TB and IACV, and changed a few sensors in the engine.
Old Dec 24, 2005 | 07:47 PM
IlyaK's Avatar
The Golden One
Also, I went into Walmart and Advanced Auto Parts...they both carry the 5w/30 oil but neither of the ATF's. What kinds of stores carry them?
Old Dec 25, 2005 | 10:21 PM
IlyaK's Avatar
The Golden One
Anyone? I could use some help. Thanks.
Old Dec 25, 2005 | 10:57 PM
konak85's Avatar
autozone pepboys or other auto store
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
