Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Brake Fluid Problem
Old Jan 18, 2006 | 10:33 AM
Nickel's Avatar
Brake Fluid Problem
my E brake light came on so i check my brake fluid. it was low so i added. i filled it to the top and the light turn off. half hour later the light turn back on and i check the brake fluid agian and is emty. I kept adding brake fluid till i got home.
I park some where dry for the night it wasnt leeking.
i turn the car on and i press the brakes and now no brakes.
I also here like air coming out the the rear tire
what can it be????
Old Jan 18, 2006 | 10:37 AM
Jeff92se's Avatar
I'm needing a caw
1) There is OBVIOUSLY a leak in the brake line somewhere. Brake fluid doesn't magicly dissapear you know.
2) Well logic says there's a leak in the rear tire.
My guess. I bet brake fluid is leaking onto the tire, eating though the rubber and is causing a leak. But mechanic diagnosis over the internet is a b!tch sometimes ya know?
Old Jan 19, 2006 | 01:41 PM
Nickel's Avatar
I found the problem. my right side brake line broke and it was leaking under my gas tank.
I got the problem fix. and i also change all 4 brakes and brake pads because there wear wornd out.
thanks,
Old Jan 22, 2006 | 07:12 PM
njmodi's Avatar
Do I get a tax break?
- now at least you're safe again.
sctludwig
Sep 1, 2022 01:32 PM
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
