Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Mixing syn and dyno
Old May 15, 2006 | 03:17 PM
konak85's Avatar
Mixing syn and dyno
I've wanted to switch to synthetic for a while but don't have the ***** to do it because some people at BITOG were getting leaks after switching. I wanted to mix about 4 quarts 5w/30 and 10w/30 Castrol GTX and a half quart of a high ester synthetic(like GC). I wanted to do this mainly for the winter. You guys see any problem with this?
Old May 15, 2006 | 03:20 PM
mtrai760's Avatar
'Trynna' is not a word
Don't mix, its a waste, you lose any benefit you would have had running the synthetic to begin with. If you really want to run synthetics, running a dose of Auto-RX first, then switch. Otherwise save your money.
Old May 15, 2006 | 04:26 PM
kcryan's Avatar
Do or do not, there is no mix
Old May 15, 2006 | 05:05 PM
Bobo's Avatar
And if you have more than 100K on the engine, do two Auto-RX applications.
I switched over to synthetic oil in February, following one Auto-RX application and have no leaks, albeit I only have 64K mostly highway miles on the clock.
Old May 15, 2006 | 06:30 PM
konak85's Avatar
actually there are many that are mixing syn and dino on BITOG without a problem. Too scared to run full syn at 130k.
Old May 15, 2006 | 06:45 PM
kcryan's Avatar
If you trust it, do it, but then if that is true whyd you ask?
Old May 15, 2006 | 11:07 PM
steven88's Avatar
Need A Light?
good point....i like how you get straight to the point...no nonsense talk
especially this line "Do or do not, there is no mix"
Maximan190
Dec 16, 2015 06:01 AM
msellas
Sep 23, 2015 09:16 PM
pjgreek
Sep 9, 2015 09:30 PM
Maxboy23
Sep 4, 2015 06:04 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
