Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Coolant for our max?
Old Feb 11, 2007 | 05:04 PM
normkit108's Avatar
I have a 04 SL and was wondering what type of coolant to use. thanks.
Old Feb 11, 2007 | 05:48 PM
Love_00_Max's Avatar
Nissan Long Life Coolant.
Old Feb 12, 2007 | 09:03 AM
ghostrider17's Avatar
Ditto that.
Long-life, borate+silicate free green Nissan stuff is the way to go.
A bit pricey, but necessary for maint-free operation.
Consider whatever warranty you have as well - this is good insurance.
gr
Old Mar 12, 2007 | 04:10 AM
lalaMAX's Avatar
i went to nissan today, they gave me a blue PEAK...
and i went to Honda for my mom's TL, they gave me PEAK too....
so i guess PEAK is what most dealer use in vancouver area... i dunno....
Old Mar 12, 2007 | 05:41 AM
My motorcycle likes the same stuff....silicate & borate free.
I went to the local honda shop last week and asked for it by name - and they sold me a gallon of 50/50 premix. $17
My local Nissan Dealer doesn't stock the 100% coolant of the same variety -- Morons.
You have to ASK for it, or they'll give you the cheap stuff.
gr
Old Mar 12, 2007 | 12:34 PM
A dealer should carry full strength Nissan coolant, if the dealer doesn't you have a problem. First he shouldn't be carrying Peak coolant inplace of Nissan Coolant and if he says it is fine to use Peak (which I used and blew up a radiator), get it in writing and fax the writing to Nissan NA headquarters, that way these id.ots at these dealerships are kept on check.
Old Mar 12, 2007 | 10:56 PM
SilverMax_04's Avatar
Originally Posted by normkit108
I . . . was wondering what type of coolant to use.
Just check the stickies above. That's what they are there for -- to answer common questions like this.
http://forums.maxima.org/showthread.php?t=278600
Old Mar 15, 2007 | 02:10 AM
lalaMAX's Avatar
is peak really that bad?
Old Mar 15, 2007 | 01:36 PM
Peak is not bad but then you will need to do a complete flush and then add it. You cannot mix Nissan Coolant with Peak coolant, which is described as OK on the back of the bottle.
Complete flush and then you will be OK.
Old Mar 15, 2007 | 03:45 PM
sky jumper
right. a *complete* flush. and a complete, 100% purge of any trapped air. then you might be ok. of course, for all this trouble you save about $2/year. only you can decide if it's worth it.
Old Mar 16, 2007 | 01:23 PM
Common guys, don't cut cornors on coolants.
Peak Global costs $10/Gallon
Nissan OEM costs $20/Gallon
You guys make the call.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
