Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Switching Octanes
Old Apr 15, 2007 | 04:25 PM
  #81
kenshi's Avatar
Originally Posted by sky jumper
the only KS code there is is P0325. it is trigger by voltage out of spec (which could be a wiring problem or a faulty KS), and it does not set the CEL. you are wrong again.
So you're saying that if you have a faulty knock sensor circuit, the SES will not light? If so, how does one tell their timing is out of spec other than performance?
Old Apr 16, 2007 | 07:54 AM
  #82
deezo's Avatar
Yes, you can have a faulty knock sensor and never see a SES light. If you do your research, you'd know it.
Old Apr 16, 2007 | 02:17 PM
  #83
kenshi's Avatar
I know you can have a faulty knock sensor and never see a light, but that's not what asked.
I asked if a faulty knock sensor circuit, which is a p0325 error, would not cause a light as sky said.
Old Apr 16, 2007 | 03:03 PM
  #84
deezo's Avatar
Ok that's out of the way, thread is closed.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
