Fluids and Lubricants Motor oil, transmission oil, radiator fluid, power steering fluid, blinker fluid... wait, there is no blinker fluid. Technical discussion and analysis of the different lubricants we use in our cars.
Idea for tranny flush...Will it work?
Old Apr 12, 2008 | 02:40 PM
jr schultz's Avatar
I know the procedure to flush your own tranny...Here's my question. Would it work to have a hose hooked up to the feed line for the radiator that dumps into a bucket, and then have the return line sunk in a bucket of fresh fluid? As the old fluid is pumped out the feed line would the return line suck up the fresh fluid? I was just wondering if it would work since it would save time from the typical return line procedure flush.
Old Apr 13, 2008 | 09:31 AM
jasonmax's Avatar
I don't think so since the AT gearbox is not air-leak-free.
Old Apr 13, 2008 | 01:38 PM
jr schultz's Avatar
Bummer. Oh well.
Old Apr 13, 2008 | 05:51 PM
joew's Avatar
if you want to save time, you may want to drain & fill. repeat after a week of driving.
Old Apr 13, 2008 | 06:09 PM
twiggy144's Avatar
You may dump the return line in a bucket, flush half a gallon, then refill with fresh fluid using the dip stick tube, repeat untill the flushed fluid comes out clear. I did this many times. Ask for a helper to switch off the engine while check the can being filled with flushed ATF.
Samedi
24
Apr 19, 2016 12:49 PM
Rage Maximus
Sep 3, 2015 12:26 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Supragte
Aug 12, 2015 10:00 PM
kenc15
Aug 5, 2015 08:29 AM
