turbo foward y-pipe for sell
I'll take 350 shipped. I bought here a couple years ago but never got around to using it, since I went through some hard times. Well I found it in the garage, putting it up for sale.
Oh some more info, its a T4 flange and has a tial 38mm wastegate flange welded on as well, and its ceramic coated. Its made for 95-99 Nissan Maximas. It uses the stock rear header with the long pipe coming foward and the other piece replaces the front header, then they are both connected with that clamp. Has both 02 sensor bungs so if you want too all you need to do it weld in another bung for a wideband.
Yes i believe so its been a long time. I believe he uses a similar setup with his car.
NICE wunfstmax made a hand full of these ,and they all seemed to be different.
Here is a link to a build thread http://forums.maxima.org/supercharge...her-turbo.html
Also noticed this may need a smaller fan to work http://forums.maxima.org/supercharge...ed-maxima.html
Did he say any what modification was need for the this specific exhaust you purchased from him? never mind I found the answer.
http://forums.maxima.org/supercharge...feed-pipe.html
Good luck with sale.
that one did not need a slim fan to work. The one I had on my car did but it was a tad different design. I'm not sure what modifications you would need to make it fit on an 02 seeing how it was made for a 95-99. If it doesn't fit and you decide to sell it it will fit either an auto or manual.
litch
123
Jan 4, 2024 07:01 PM
Stagnet04
Oct 11, 2015 08:16 PM
