Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Tried to Remove Strut Bolts With Socket Wrench
Old Jun 20, 2004 | 09:56 PM
VQuick's Avatar
Chassis Freak
Used a long breaker bar and PB Blaster, but boy were those mothers rusted on there. Luckily the two sockets are Craftsman so I'll get some free replacements.
Tomorrow I'm going to use air tools (didn't have the compressor today)....
Old Jun 20, 2004 | 10:00 PM
dmontzsta's Avatar
Ford Only.
dude, in all my days and years of working on cars I have never had tools fail like that. ESPECIALLY Craftsman, did you have them on straight when using them? something went wrong, that should not have happened. At any rate, take them back to Sears and get new ones at no charge with no receipt.
Old Jun 20, 2004 | 10:16 PM
VQuick's Avatar
Chassis Freak
Yes, on straight and yes, I was surprised that I broke them. I was using a breaker bar about 2.5 feet long, and that's quite a bit of force. I wasn't going the wrong way or anything because I got one bolt loose before breaking the extension and then two sockets.
BTW the extension doesn't say Craftsman so I assume it's generic/cheapo.
Keep in mind you live in SoCal and may not be familiar with cars with 5+ years of RUST. Rust is amazingly good at fusing metal parts together.
Old Jun 20, 2004 | 10:24 PM
RobUsaf81's Avatar
Wow, thats some mean rust. Would have expected the bolts to go first.
You ever get the bolts off?
Old Jun 20, 2004 | 10:35 PM
VQuick's Avatar
Chassis Freak
Nope, will be using an impact wrench tomorrow.
The bolts are fine by all appearances.
Old Jun 21, 2004 | 12:53 AM
Nealoc187's Avatar
SLOW
I broke 2 sockets and a 3/8" breaker bar doing my front strut bolts as well. Craftsman replaced them though as promised.
Old Jun 21, 2004 | 07:28 AM
MaximaPolak's Avatar
You sure nissan didn't weld your bolts in?
Old Jun 21, 2004 | 10:08 AM
MAXimumHP's Avatar
I've seen that before too. If you use impact sockets and extensions they are much stronger. Never had a 1/2" breaker bar bust on me though, even with two feet of pipe off the end. I have seen them break though where the socket attaches a couple times.
Old Jun 21, 2004 | 11:13 AM
95stillenmax's Avatar
dang I have never broken a craftsman socet the only ones I have broken are like some cheap made in china ones
Old Jun 21, 2004 | 11:30 AM
SkoorbMax's Avatar
I will be buying craftsmen in the future, but trying to take a wheel of after those ****s at the tire stores crank them on with a million-lb of torque impact tool I've broken now two wheel studs and also an extention (it was a walmart cheapy one), all three times using my breaker bar.
I dunno about you guys but I feel manly when I am strong enough to break a tool and I know that the tool failed me, and not the other way around
Old Jun 21, 2004 | 01:14 PM
Zero Deuce SE's Avatar
Were you using a 3/8" drive or 1/2"? I can't see breaking 1/2" drive on strut nuts.
Old Jun 21, 2004 | 01:59 PM
VQuick's Avatar
Chassis Freak
Ya, 3/8" drive. Don't have 1/2" drive in a 17mm socket. Impact will do the trick.
SkoorbMax, I hear you. I thought the bolt was finally loosening with a satisfying little jerk, but then I saw I'd wrecked the socket and thought, damn, I'm strong!
Old Jun 21, 2004 | 02:19 PM
An impact is nice to have even though I have never owned one. I use them at my job though. If you plan on doing a lot of work on your car, it would be a good idea to invest in some 1/2" drive tools for the times when you can't use an impact.
Old Jun 21, 2004 | 07:49 PM
Broaner's Avatar
2060lbs and falling...
I'm suprised nobody has noticed this. Tom it looks like the sockets took a beating but it is totally okay to use the impact sockets on a regular socket wrench. There should be a 1/2" extension and swivel somewhere in the toolbox. Those fxckers won't break.
Old Jun 21, 2004 | 08:39 PM
MrDicks95SE's Avatar
Offset Is Everything.
eh wait why would you need an extension in the first place to loosen strut bolts? would it not clear the fender or soemthing when you used the breaker bar? there should be enough room to use a standard socket wrench (wiht no extenstion) and breaker bar. i think thats why it broke... i could be wrong tho.
but still those bolts are held on there pretty tight if you broke something like that. did you WD40 those mothers? dunno if its safe to.
Old Jun 22, 2004 | 03:09 AM
Swivels will break when using them with an impact gun. We break them at work every now and then when working on bulldozer undercarriages. They are designed for impact use and still break sometimes. I have never seen a broken extension though.
Old Jun 22, 2004 | 04:37 AM
I30tMikeD's Avatar
I bet you were trying to loosen the bolt side not the nut side. I broke an impact socket (cheap one though) cranking on the bolt side.
Old Jun 22, 2004 | 06:01 AM
I was trying to remove the rockguard bolts on a bulldozer. There are no nuts on them. They tend to get rusted into the bolt holes.
Old Jun 22, 2004 | 06:07 AM
endus's Avatar
An atavistic endeavor...
Wow! Would definitely have expected the bolts to break or the head to strip before the socket breaking....woo! Glad I have air and an impact wrench now for when I change to illuminas.
Old Jun 22, 2004 | 06:11 AM
I30tMikeD's Avatar
uuhhhh...OK....great?? I did not quote your post.....it was directed twords the one who started this thread.
Old Jun 22, 2004 | 08:36 AM
All righty then.
Old Jun 22, 2004 | 08:51 AM
VQuick's Avatar
Chassis Freak
I didn't have a socket deep enough to put on the nut end because of the amount of bolt thread sticking out.
Give me a reason why it would matter one way or the other, because I can't think of one.
Old Jun 22, 2004 | 10:33 AM
I30tMikeD's Avatar
Because it's harder to turn the whole bolt than just the nut. The bolt may be wedged against the steering knuckle in a way that won't allow it to turn.
I have removed those bolts many, many times. I only had problems one time, and that was when I was trying to remove the bolt side and not the nut side. that was when I broke my impact socket (not using an impact gun)
Old Jun 22, 2004 | 11:02 AM
RA030726's Avatar
I'm nutty for Nissans
the sockets are 1) not deep enough, 2) 12 point (the 6 point looks like china crap to me), 3) not impact sockets, and 4) 3/8" drive....but ive been in the same boat it stinks. The best deep impact metric socket set for the money is at Wal-Mart, its 1/2" drive and under $20 for the set, 10mm to 23 or 24mm. Then get the Huskey (homedepot) or Crappsmen 1/2" breaker bar and ratchet. Good luck next time.
Old Jun 22, 2004 | 11:15 AM
spirilis's Avatar
3/8" drive, there ya go... I always use 1/2" drive tools when possible
Strut bolts/nuts are usually STILL a b**ch though...
Old Jun 22, 2004 | 12:57 PM
2k3TitaniumSe's Avatar
Wow! Can't believe that happened to the Craftsman tools.
Old Jun 22, 2004 | 01:52 PM
5 spd's Avatar
have you used penetrating oil prior to loosening up the hardware?
Old Jun 22, 2004 | 02:02 PM
Kashoggio's Avatar
craftsman suck.... snap on is the best
Old Jun 22, 2004 | 03:13 PM
Care to elaborate on why they suck? Craftsman tools have the same warranty as Snap-On tools do except it's easier to get a Craftsman tools replaced by just taking it to your local Sears store. With those high priced Snap-On tools, you have to wait for the tool truck to come by to get a replacement. I have both brands and Craftsman is all the average mechanically inclined person needs. I have seen many different brands of tools fail.
Old Jun 22, 2004 | 03:14 PM
That's what the PB Blaster is.
Old Jun 22, 2004 | 04:17 PM
VQuick's Avatar
Chassis Freak
Makes sense. Thanks, I'll pick up a 17mm deep impact socket if a search of Broaner's garage doesn't turn up one....
Old Jun 22, 2004 | 04:19 PM
VQuick's Avatar
Chassis Freak
Good eyes! You're right, the 6 point says only TAIWAN instead of CRAFTSMAN. I broke that first then switched to the 12 point Craftsman, which didn't break nearly as badly (just a little crack).
Again, it was only a last resort that I was using 3/8" drive regular sockets because the friend that was supposed to bring over the compressor for the air tools failed to do so but I still really wanted to put on my new struts/springs.
Old Jun 22, 2004 | 06:20 PM
Broaner's Avatar
Tom, this is how I did it the first time. This was before I had the compressor. I used the 17mm and 19mm box end wrench. We put rags around the handles of each and pulled in the opposite direction(Me in one, Ross in the other) It took many tries to break it loose. Now, w/ the compressor its very easy. Wrench on nut side, impact wrench on the other. Seeing as I adjust my camber once a month this is a three finger job really. The first time is always the hardest especially since its a northern car.
Old Jun 23, 2004 | 08:54 AM
VQuick's Avatar
Chassis Freak
That's what I told her.
j/k Thanks Broaner. Gonna try it tonight, as long as Ross didn't sneak back and take his compressor back. He's not answering either phone right now.
Old Jun 23, 2004 | 12:23 PM
happyricefob's Avatar
V^___^V
1. use torque wrench
2. don't use "flower" head socket
Old Jun 23, 2004 | 02:15 PM
Mr. Peabody's Avatar
I actually broke the ratcheting part of a 1/2" drive. Ok Ok I was using a 4' breaker bar that I slipped over the 1/2" drive.
The guy at Sears was astounded. After he handed me my new 1/2" drive he said OK now that you have your free replacement tell me just how long was the extention that you put on the end.
Oh yea I was trying to remove a rusted on castel nut holding the rear wheel of a 71 VW onto the axel.
Mr. P
Old Jun 23, 2004 | 02:34 PM
Kashoggio's Avatar
craftsman tools are very poorly designed, aswell as the cheap meterials they use. I use my tools everyday, thats what i get paid for. I have used craftsman tools and the cant take a beating but for a home user I guess they do just fine.
Old Jun 23, 2004 | 04:20 PM
sk24iam's Avatar
Air tools took mine right off.
Old Jun 23, 2004 | 04:35 PM
craftsman tools are very poorly designed, as well as the cheap materials they use. I use my tools everyday, thats what i get paid for. I have used craftsman tools and they cant take a beating but for a home user I guess they do just fine.
I kind of figured that you were a gearhead when you spoke well of Snap-on tools. I like the quality but hate the prices. I work as an equipment mechanic for the state of Florida. We don't have to supply our own tools so I am lucky in that respect.
Old Jun 25, 2004 | 04:41 AM
Kashoggio's Avatar
yeah not paying for tool must be nice, but i rather pay more and not have a tool break on my during a job... that a ****es me off
