Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Heating A Garage
Old Dec 20, 2007 | 06:26 AM
  #41
eng92's Avatar
Originally Posted by doublea
First thing I would suggest is that you insulate your garage as it's not expensive. I have installed a 4800 watts Ceiling Fan-Forced Diffuser. It heat the garage in no time and it tonly cost 450$ cdn.
http://www.ouellet.com/residential-h...-usa.aspx?i=56
I guess it depends on how long term of a solution you are looking for and if NG is available in your area. If I plan to stay in a house for more than 5 years then I would go with NG hands down over electric for a heating appliance
A 4.8kW electric heater will cost you 43 cents/hr to run at a typical electricity rate of 9 cents/kWh
The equivalent output NG heater will cost 18 cents/hr to run at a typical gas rate of 35 cents/m^3. (assuming a heater efficency of 90%)
That is a 240% difference in operating costs.
Old Dec 20, 2007 | 11:03 AM
  #42
spdfreak's Avatar
That fan gives me some ideas.
I'm not sure which route I will go. NG or a Wood Pellet sove.
I will have to wait till it gets warmer outside to re do my garage. It's in need of a new shelf layout. It's too cold these days, so for now I picked up a propane heater. It's the one that goes on top of the tank (in my case 20 lb'ers) and has two heating domes that can be pionted in their individual directions. It's an upgrade from my single unit.
Old Dec 21, 2007 | 06:35 PM
  #43
Professor's Avatar
I just use my 125,000 BTU jet engine looking heater thats so loud you have to yell to have a conversation, it uses Kero, diesel, or jet fuel. heats fast but woo it gets hot and when it shuts off, it dont take long to get cold again ><
Old Dec 21, 2007 | 07:27 PM
  #44
z00york145's Avatar
I saw this at costco the other day, I have something similar to this and it seems to work just fine on long projects.
Here is the link.
Old Dec 22, 2007 | 06:44 AM
  #45
doublea's Avatar
In Qc the electricity is so much cheaper than other place in Canada & USA, it cost me no where near the amount you are referring. I pay .052 cents/kWh and I use an electronic thermostat to control the temp. When I'm not in the garage I keep it a 50F, all in all it may cost me 15-20$ per month to heat the garage.
NG was not an option since the infrastructure are not done in my area, just for that alone Gaz metro would have charge me over 3000$ just to bring the gaz to my home, then I would have had to use at least 3 device that burn NG. Also it's mandatory here to choose a certified NG heater which will run another 1500 -2000$ we cant use a construction heater inside a garage it's not legal or safe.
Old Dec 22, 2007 | 12:39 PM
  #46
eng92's Avatar
The electricity commodity rate in Ontario is also 5.2 cents/kWh but we also have to factor in the delivery, debt retirement and regulatory charges as well.
$20/month eh. That only works out to be about an 11% duty cycle on that heater. Do the heater and fan outputs vary with the heating requirement?
Old Jan 16, 2008 | 06:15 AM
  #47
redls1's Avatar
MAXIN' ON
Sorry to bring this thread back but there were alot of suggestions in here. Now that its cold here in tn. I want something to heat the garage to do a little work. I saw a portable garage ceramic heater at lowes. I heard those use alot of electricity. If I went propane I could use the grill tank when not using it and then put it back. Ive got 2 windows in the garage I could use to vent. Im looking for somerhing very inexpensive at the moment. I also saw a oil filed radiator heater that the guys at lowes suggested. It had a listing of what btu"s it would take to heat a room size but never said what the btu"s the unit put out. I dont have to heat the whole garage but just want to bring up the temp alittle while under the car. More suggestions please.
Old Jan 18, 2008 | 06:08 PM
  #48
BenStoked's Avatar
Jesus was a Zombie.
I think a propane heater would be okay. just remember, if you use a fuel, make sure to get a CO Detector.
Old Jan 19, 2008 | 03:04 PM
  #49
redls1's Avatar
MAXIN' ON
Think I am going to get something like this
http://cgi.ebay.com/5674-Propane-Con...QQcmdZViewItem
Old Feb 13, 2008 | 06:07 PM
  #50
spdfreak's Avatar
Update.
After some research I may use spray insulation from Home Depot. Total cost for my garage should be around $400.
Old Apr 25, 2008 | 12:58 PM
  #51
sam_918's Avatar
Be a man, don't heat.
Besides numb hands don't hurt as much when you bust a knuckle.
I do heat though, and I use a torpedo heat slightly pointed toward the ground and under the car because a wet floor and snow falling on my face pisses me off more than the chilly air.
Old Jun 12, 2008 | 10:33 AM
  #52
SamMan23's Avatar
I work for a HVAC company and most dealership garages are fitted with gas fired tubular radiant style heaters suspended from the ceiling.
After talking to a vender who sells the product, this makes the most sense. It will heat the floor without having to build up all the heat in the whole room. That way, if you open your garage door, you don't have to heat the whole room all over again.
But the costco radiant style heater above is a good cost effective way of just providing heat where you need it.
Old Aug 5, 2008 | 02:25 PM
  #53
highpressure's Avatar
they make special heaters you can bolt to your rafters that project heat down actually there are microwave ones for sale that just heat the surface of things and then the air is heated through the surface of stuff
Old Sep 3, 2008 | 07:53 AM
  #54
ZGadson's Avatar
Ive actutally got a seperate furnace for my garage. I got it for free, so if it wasnt for that I wouldn't have a heated garage. I also already had insullated walls in the garage or I wouldnt have even wanted the furnace. All I did was fill the garage door with that yellow sealant foam crap to insullate the door and installed the furnace in the attic above the garage. All it costs me was the cost of the foam insullation can, some wires/ductwork, vents for the ceiling in the garage, and time. $200 total.
Old Jan 17, 2009 | 08:46 PM
  #55
jlidon's Avatar
I am wanting to save my money to insulate our garage. I was not sure whether to do just the lower half and close off the upstairs or do both levels right away. What do you recommend for the walls and ceiling?
Old Jan 18, 2009 | 10:03 PM
  #56
rollin-on-dubs's Avatar
I insulated my walls and ceiling and my garage stays at about 45 degrees in the cold winter days and nights.
Old Jan 18, 2009 | 10:17 PM
  #57
Bjs470's Avatar
I should have seen this thread 2 months ago
Old Jan 19, 2009 | 08:32 AM
  #58
eng92's Avatar
Are your walls open studs right now?
Use R12/13 for 2x4 and R20 for 2x6.
What access do you have to your ceiling? Were you planning on going with batts or loose fill (cellulose fibre)?
Old Jan 19, 2009 | 08:34 AM
  #59
eng92's Avatar
Where are you located?
If it stays that warm without a heater, that does not say much for the insulation in your house.
Old Feb 3, 2009 | 06:39 AM
  #60
ks02max's Avatar
The heater I just got for my shop. It is a gas heater, but I got the propane switch over kit for it. My building is 40x70x12.
Old Feb 3, 2009 | 11:43 AM
  #61
BEJAY1's Avatar
Conecarver
Great thread. I've got an uninsulated gdoor, ceiling, and 2 walls now and it was 25deg last night changing out a strut mount. Thanks for all the info!
Old Feb 3, 2009 | 01:41 PM
  #62
Matt93SE's Avatar
STFU n00b!
for the garage door, glue some 1" thick styrofoam sheets to the back and cover with some sort of vinyl backing to make it look better. that's what's on the back of my gargae doors and it works wonders.
walls and such you can use fiberglass, but styrofoam is cheap and is an excellent insulator. (i.e. a 3.5" thick piece of foam for 2x4 walls is good for R40 rating. 5.5" to go inside a 2x6 rafter is R60!!!!)
Old Feb 3, 2009 | 02:05 PM
  #63
eng92's Avatar
Are you referring to white or blue board?
I was looking at using rigid board when I did my walls, but all my information sources showed R-values of 4 and 5 per inch for the white and blue respectively.
It is kind of a pain to work with if you have any significant amount of wiring or plumbing running through your walls.
Also, around here they throw the houses up with wreckless abandon so the stud cavity sizes can vary by up to 1/2" from one to the next as well as from top to bottom.
Old Feb 3, 2009 | 02:49 PM
  #64
Nopike's Avatar
Unless you really spend a lot of time working on your car in the winter months this seems like overkill. Consider investing in some long johns. I spent two hours working on my car the other night, it was 20 degrees outside. Between being dressed properly and the activity working on the car I was toasty. Could have easily spent another couple hours out there with no problems, but it does make it more difficult to have a beer while working.
Old Feb 3, 2009 | 03:24 PM
  #65
eng92's Avatar
Speaking for myself, I am not heating the garage for personal comfort.
You cannot paint or do fibreglass work when the ambient temperature is below freezing.
Also, I keep all of my hazardous materials (solvents, paints, adhesives, etc.) in a locked garage to eliminate the possibility of any of my children doing themselves harm.
Old Feb 3, 2009 | 05:29 PM
  #66
Matt93SE's Avatar
STFU n00b!
Nope. I'm talking about styrofoam.
my folks built their house out of a similar brand of product a few years ago...
http://siperiorhomes.com/index.htm
4500sq ft house, 3 floors, and they run a 1 ton AC unit when it's 110 deg outside.
Old Feb 4, 2009 | 04:46 AM
  #67
BEJAY1's Avatar
Conecarver
Yes, but it wasn't my body that was cold. Feet from standing on cold concrete, fingers from contact with frozen metal parts, tools, etc. Even swapping warmp work gloves only helped a bit. An extra 15deg warmer would've helped alot.
Old Feb 4, 2009 | 05:38 AM
  #68
eng92's Avatar
White and blue board are industry references for two types of styrofoam product made by Dow Chemical.
That link refers to a EPS/OSB composite panel. They rate the 6.5" thick panel at an R-value of 25.
http://siperiorhomes.com/SIP_facts.htm
Do you have a link to the product you were referring to here?
I have not insulated my ceiling yet so I am exploring all the possibilities.
Old Feb 4, 2009 | 06:12 AM
  #69
Matt93SE's Avatar
STFU n00b!
Nope. They built the house 12 years ago and I forget the supplier of their products.
As for post-construction insulating a garage door, I just mean go to Home Depot and buy the sheets of cheap squeaky styrofoam and glue them to the door. that blue/white stuff in the construction materials section is $$$ compared to the el cheapo crap. and the cheap stuff works just fine assuming you take care in working with it.
Old Feb 5, 2009 | 07:23 PM
  #70
maxger's Avatar
Does your ceiling and walls have a vapor barrier? Is the ceiling drywalled? Insulating without a good vapor barrier could cause rot and moisture problems also.
Here is a pic of our attached garage when we built our house.Blown cellulose in the ceiling was not installed then. The garage is air tight. The only drafts are from aound the insulated garage doors.
Old Feb 6, 2009 | 01:48 PM
  #71
eng92's Avatar
A vapor retarder is only a requirement when you have significant moisture sources in the room. I do not bathe or cook in the garage and my forced air NG heater vents externally.
The garage ceiling was drywalled and taped when we moved in. There was
no separate plastic vapor retarder installed. Although more and more codes now are considering a drywalled and taped (and painted ceiling) to be sufficient and no separate plastic layer is required.
Old Feb 14, 2009 | 03:53 PM
  #72
maxger's Avatar
Sorry about the late post. Actually a few coats of paint is just fine or you can use thishttp://www.hytechsales.com/prod85.html
We park one of our cars in the garage during the winter and with the snow and slush from the car the garage has a high moisturel level.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
