Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Leak Down Test vs Compression Test
Old Nov 15, 2008 | 06:06 PM
1993-VG30E-GXE's Avatar
I'm looking to buy a tester, but for now money is tight so I can only buy 1. The Cylinder Leakage Tester (Leak Down Test) is only a bit more in price than a standard Compression Tester.
Can the Leak Down Tester perform all the tests the Compression Tester can do plus more? Is this the one I should buy?
Old Nov 16, 2008 | 11:47 AM
whlimi's Avatar
http://www.dietersmotorsports.com/Co...akdowntest.htm
Old Nov 16, 2008 | 04:15 PM
Aaron92SE's Avatar
NWP Engineering.com
You can get a compression tester for under $10 at Harbor Freight. Works just fine.
But a leak down tester is much better. It will tell you exactly WHERE you are loosing compression (rings, intake valves, exhaust valves, or head gasket).
Old Nov 16, 2008 | 09:09 PM
Aaron I picked up that leakdown tester. It says it has a "universal 14-18mm adapter". Is this metric thread adapter going to thread into the 3rd gen holes? I thought I remember buying a 5/8 SAE spark plug socket.
I'll wait to hear back before I remove it from the packaging in case I need to return.
Old Nov 17, 2008 | 07:02 AM
Aaron92SE's Avatar
NWP Engineering.com
14mm will work. It's a VERY common size. Open that package up! You got it right.
14mm is the size of the actual threads of the spark plug hole. 5/8" is the socket size for the spark plug.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
