Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Need To Cut Into Firewall...
Old Jan 26, 2009 | 07:10 PM
shyheim07's Avatar
Whats the best tool/ accessories here?
Trying to get big enough holes to put (2) 0 Guage wires through.
THanks
Old Jan 26, 2009 | 08:36 PM
AceofSpds's Avatar
wat
Dremel, drill series of holes, Use stone/sanding wheel attachment to even it out.
Old Jan 27, 2009 | 08:22 AM
300zmax's Avatar
THanks
i suggest a stepped drill bit avalible for cheap at harbor frieght and drill one hole for each wire then add rubber grommets from Mcmaster.com or sears hardware. i suggest painting the fresh metal after with krylon or something similar befor putting the grommets on.
Old Jan 27, 2009 | 02:06 PM
RA030726's Avatar
I'm nutty for Nissans
http://www.irwin.com/irwin/consumer/...l?brand=Unibit
LOVE THESE
Old Jan 27, 2009 | 05:23 PM
eng92's Avatar
I ran my 0 ga. through the fender alongside the cable release for the hood (4th gen) No drilling required.
Old Jan 29, 2009 | 08:32 AM
zero2sixtyZ's Avatar
You embarrass me.
+1. Did this for my 4 ga. on my 5.5gen. No additional holes, but it was a pain to run through.
Old Feb 1, 2009 | 09:20 PM
djfrestyl's Avatar
Suspension Yoda
+1 on the unibit.
This thread might have been more relevant in the audio section.
Old Feb 1, 2009 | 09:55 PM
96blkonblkse's Avatar
Yeah i used the same grommet for the hood release, just sliced into the grommet a bit and patched it up with some silicone after.
Id reccommend against drilling into the firewall if possible, but if you do, make sure you paint it with some POR15 or rust inhibitor or it'll rust like a 80s circa ford.
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
