Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
scary story about my dad jack failing.
Old Jun 16, 2009 | 11:45 PM
whiteSE's Avatar
i just think it would be a good pre cation, and a lesson for me. i screwed up.
anyways, i got some 350z rims for my car, went to a tire shop to put valve stems into them, and had them balanced. pulled away into a parking area, and decided to install the rims. i jacked up my car, rear left, changed the tire, rear right, then i untightned the front right tire, jack up the car, using the same 2 ton hydralic jack, take of the old rim, and then the car started to slowly fall down, like a inch every 3 seconds, so i panic, try to put the rim back on the lugs, but the car already was to low, and also, the rim got stuck but the car was still falling. so i get the jack from the trunk and started jacking up the car up with it. luckly, the car didnt fall all the way, and the rim didnt get bent. i changed the last tire, using my factory jack. i got kinda freaked out beacasue i was supposed to change my oil soon, and i was most likely going to use that jack. now im probably going to throw it away.
i did check the locking thing on the jack, where you release the presusre, and it was closed. WTF? pep boys jack FTL. anyone have experince like this with crafstman jacks? im going to get that next.
Old Jun 16, 2009 | 11:54 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Why didn't you give the jack a few pumps to raise the height?
Old Jun 17, 2009 | 12:08 AM
whiteSE's Avatar
i did, but nothing, it kept on falling
Old Jun 17, 2009 | 12:12 AM
Leo_Koneval's Avatar
Wow that is scary, I'm glad you didn't get hurt. I mean if that happened while you were under the car taking out the transmission or whatever, it would be a disaster.
Old Jun 17, 2009 | 12:17 AM
whiteSE's Avatar
yep. so im thinking of buying a new jack...wat do u guys recommenced?
Old Jun 17, 2009 | 12:38 AM
SEmy2K2go's Avatar
Go BUCKS!!!
http://forums.maxima.org/garage/5874...loor-jack.html
Old Jun 17, 2009 | 07:25 AM
1993-VG30E-GXE's Avatar
Only an idiot would go under a car supported by a jack though.
Even for accessing the drain plug OP!
Old Jun 17, 2009 | 07:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
JACK STAND!!??!! c'mon!!
Old Jun 18, 2009 | 12:32 AM
whiteSE's Avatar
thanks
Old Jul 6, 2009 | 11:03 PM
Mu_036sp's Avatar
i always use my Jack stands! thank god you and your car is okay
Old Jul 6, 2009 | 11:09 PM
whiteSE's Avatar
thanks. i use stands now every time i jack up the car.
Old Jul 7, 2009 | 07:10 AM
mannetti21's Avatar
I guess for some people it takes one of these oh **** moments to do things the right way. I have 4 jackstands and I usually use all 4 whenever I'm under the car for anything. you gotta remember that if the car falls you probably aren't going to survive.
Old Jul 7, 2009 | 07:21 AM
B_Eaze's Avatar
I ALWAYS use jack stands and if Im taking tires off I put those under the car for a back up...
Old Jul 7, 2009 | 07:26 AM
secondtonone317's Avatar
nycnissans
USE THEM!!!
Old Sep 28, 2009 | 11:09 AM
Marlin's Avatar
Wow scary!!
Old Sep 28, 2009 | 11:36 AM
Kquezada28's Avatar
lol i would have been ****ting bricks and screaming like a little girl....but definitely use like 4 jacks next time
Old Sep 28, 2009 | 12:02 PM
Conrad283's Avatar
I need a truck
Jack stands ... Always.
Old Sep 28, 2009 | 01:35 PM
whiteSE's Avatar
yeah. thats what i do from now on. i never use tat jack agian either
Old Sep 28, 2009 | 02:20 PM
ampire's Avatar
You can also shove one of your spare wheels under the jack points on each side as a precaution. I have a set of racing wheels off of a old porsche and I throw them underneath the doors by the jack points depending on what Im doin.
Old Sep 28, 2009 | 02:43 PM
Slightly old thread....but I'll contribute that I've read the reviews for Craftsman jacks, and apparently they suck big time.
Old Sep 28, 2009 | 02:49 PM
vntperformance's Avatar
Talk about a funny story. Jack stands ftmfw!
Old Oct 16, 2009 | 11:55 AM
doublea's Avatar
This happend to me with 2 brand new hydraulic jack, both where missing hydraulic oil so you wanna check that. I have 4 hydraulic Jack ( 2 ton each ) and 4 x Jack stand so whenever i lift the car I use all of the 8 jack sometime I even put some 8 x 8 wooden pieces. Some say I'm fanatic, but at 48 I never had a single injury because of faulty jack.
My rules of thumb is to always use at least 2 level of security but most of the time I use 3.
Good luck.
AA
Old Oct 16, 2009 | 03:23 PM
I use two jacks whenever I raise the car
But jack stands are expensive, $40 for two at Schucks. I guess $80 bucks for a set of four is not worth dying in a uncomfortable position over
Old Oct 16, 2009 | 11:16 PM
nyana107's Avatar
no need to throw it away. just pump some new hydraulic fluid in there. while you're at the store getting some hydraulic oil, buy some jack stands foo!!!
Old Oct 17, 2009 | 11:09 PM
Mr. Blue Sky's Avatar
around 18 years ago my dad had his 300zx fall on him because he trusted a jack too much. Luckily it wasn't a sudden fall, it was more like what you were describing about it slowly falling, except he was busy underneath the car, so he didn't notice at first. When he started to notice that it was starting to crush him, he called out to us and we were able to get the jack to go up again. We have never lifted up a car without placing jack stands on it since(no matter if it is a simple thing that will only take a couple of minutes). I am glad my father didn't lose his life because of a simple mistake(I was 6 at the time).
I read that jacks need continual maintenance on them, and that the lack of maintenance is the most common mistake that many people make when dealing with their floorjacks.
Old Oct 20, 2009 | 03:39 PM
Rood's Avatar
Funny, I have craftsman professional jack and jack stands and they work amazing. I also have cheap autozone jackstands that seem to work great too.
Old Oct 23, 2009 | 07:34 PM
What's the kind of maintenance I should be doing on my jack? I wasn't aware of that.
Old Oct 24, 2009 | 12:43 PM
B_Eaze's Avatar
I don't believe floor jacks need regular maintenance unless you use it multiple times a day but I could be wrong..... but what I do know is that if you use jackstands it won't matter if your jack is failing cuz you won't be under the car when it does fail
jack stands
/thread
Old Jan 14, 2010 | 01:58 PM
newspeed's Avatar
I can't believe there are people that would go under a car without jack stands. I sometimes even use 2 jack stands on every corner for extra paranoia... Only takes a minute or two to place them but they can save your life.
Old Jan 14, 2010 | 10:54 PM
NismoMax80's Avatar
SuPeRmOd
wait if u paid for balancing and valve stems... why not just let them put the wheels on??
Old Jan 15, 2010 | 01:12 AM
whiteSE's Avatar
well i was working at wendys at that time. i had to save as much as possible to survive. lol
Old Jan 15, 2010 | 08:40 PM
NismoMax80's Avatar
SuPeRmOd
i just said bc it was included as far as i knew... i'm all about saving nickels too. if i saved a few i would do it myself bc i want to avoid air guns and over-torquing as well. getting new wheels this spring. before i didnt care bc wheels already got ruined.
Old Jan 15, 2010 | 09:43 PM
whiteSE's Avatar
they wanted 20 to install the rims. plus that shop already screwed up my dads dodge caravan lugs and my bros tundra lugs as well
Old Jan 18, 2010 | 02:39 PM
Fr33way™'s Avatar
Wild for Width
It's mainly the seals and that it is filled with fluid.
Old Jan 20, 2010 | 10:11 PM
blahzace's Avatar
oh damn, becareful next time and post some pics of the car w/ the z rims!
Old Jan 20, 2010 | 10:56 PM
whiteSE's Avatar
the car was sold like 4 months ago
Old Jan 23, 2010 | 05:07 PM
NismoMax80's Avatar
SuPeRmOd
lol he just wants his 15
Old Jan 23, 2010 | 09:04 PM
whiteSE's Avatar
i guess...but we were all like that b4
Old Jan 26, 2010 | 05:39 AM
essential1's Avatar
My axles cry for mercy...
USE JACK STANDS FOR EVERYTHING!
I had a car fall on me because of carelesness with jackstands guys. I was doing a job that was only gonna take me between 5 to 10 minutes under the car. But thats all it takes for something to happen guys.
The car fell on my head. the control arm was sitting on the side of my face and the brake rotor was sitting on my chest. I was pinned under there for about a minute and a half before my dad and brother were able to lift the car. I had 29 stitches in my face and 3 staples behind my ear. I'm very lucky to only be left with a pretty nice scar.
But bottom line guys, JACKSTANDS JACKSTANDS JACKSTANDS. I dont wish what happend to me to happen to anyone else. Stay safe guys.
Old Feb 22, 2010 | 11:15 AM
A-BOY's Avatar
now you will use stand
