Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
bad idleing
Old Jun 10, 2012 | 06:06 PM
johnsonmaxima's Avatar
bad idleing
My car is idleing really bad i know im not good but i just got a full tune up about two months ago. The car acts like it wants to die eveytime i stop at a stop sign or light. When you push on the gas it goes ok but my check engine line is flashing. Dose anyone know anything of what it could be??? i have a 2003 Nissan Maxima GLE V6
Old Oct 1, 2012 | 09:33 PM
ovilla's Avatar
Sounds like you need to clean the MAF (mass air flow sensor) or possibly replace it. Make sure you use MAF cleaner. Anyway (before you do anything) when the light comes on again, take your car to Autozone and have them pull codes for you with their reader, then look up the codes on the internet.
Old Oct 3, 2012 | 10:45 AM
cw96's Avatar
Check for vacummn leaks. One of the main culprits of idle problems. Best way to check is with a smoke machine which not to many home mechanics have . Shade tree mechanic way is to take starter fluid and spray around the intake manifold ,vacumm lines or suspect leaking areas. Engine will rev up when you hit the leak just be careful because spraying either on a hot motor can cause a fire . I usually do this when the motor has not been run for a while .Of course if you have a check engine light pull your codes first to see what the computer is telling you.Good luck
Old Oct 3, 2012 | 10:51 AM
Isn't a flashing CEL a misfire? Go to Autozone and have the car scanned then report back with the code(s).
Old Feb 6, 2013 | 07:42 PM
Azmax61's Avatar
I have a misfire and it flashes ses. Im doing plugs and a few coils. Hope it solves it.
Old Feb 8, 2013 | 01:52 PM
maksi's Avatar
My 2000 maxima GLE has the same issue; however, my service engine light is on. According to the computer it's my rear oxygen sensor. I've been lazy to replace the sensor.
on a side note: I've noticed the shaking being worse with lower grade fuel.
Miket2006
Mar 1, 2021 03:55 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
