FS: Auto Enginuity w/Nissan Enhancement
Old Mar 15, 2007 | 11:56 PM
Nietzsche's Avatar
I have a brand new (ver. 4.4.1) copy of Auto Enginuity w/Nissan Enhancement. This is probably the best OBDII setup for all vehicles and you can get enhancement modules for pretty much any make. It will read all codes, moniter your OBDII sensors, datalog and with the enhancement module you have access to all functions of the ECM. Below is a list of things it can read/control. It will do +/- 2 degrees timing, adjust idle, ECM reset, and a host of other things. It also comes with speedtracer. This is an awesome program for charting your mods and logging your cars abilities. It will give you Acceleration 0-60, 1/8 mile spped and ET, 1/4 mile speed and ET. Deceleration 60-0 and calculated drag(great for testing brake mods). A "rolling chassis" dyno program that operates on the same principles as a chassis dyno. There is a boost pressure function for turbo/supercharged vehicles, a volumetric efficiency calculator, and a MPG calculator. It's great tool for not only Nissan but all other vehicles. Looking for $325 shipped. It's worth $365 shipped from AE but I realize I have to take a loss, unless you want to pay what I did.
$325 Shipped!!!
Enhanced Nissan Module List
Sensors Commands
Supported Systems
CANBCM CANDifferentialLock CANLaneDepartureWarning
CANMeterAC Enhanced4WD EnhancedABS
EnhancedAutomaticTransmission EnhancedBCM EnhancedPowertrainNewEngine1
EnhancedPowertrainNewEngine2
CANBCM Sensors
Accessory On Switch Air Conditioning Switch Auto Light Switch
Back Door Switch Blower Fan Switch Brake Switch
CDL Lock Switch CDL Unlock Switch Door Switch - Driver Side
Door Switch - Passenger Side Door Switch - Rear Left Side Door Switch - Rear Right Side
Engine Run Front Fog Switch Front Washer Switch
Front Wiper Hi Front Wiper Interval Front Wiper Low
Front Wiper Stop Hazard Switch Head Lamp Switch 1
Head Lamp Switch 2 Hi Beam Switch Hood Switch
Ignition On I-Key Lock I-Key Panic
I-Key Power Down I-Key Trunk I-Key Unlock
Key Cylinder Lock Switch Key Cylinder Unlock Switch Key On Switch
Keyless Lock Keyless Panic Keyless PBD
Keyless PSD L Keyless PSD R Keyless Trunk
Keyless Unlock Light Switch 1st Oil Pressure Switch
Passing Switch PKB Switch Rear Defogger Switch
Rear Washer Switch Rear Wiper Interval Rear Wiper On
Rear Wiper Stop Rear Wiper Stop 2 Trunk Cylinder Switch
Trunk Open Motor Turn Signal - Left Turn Signal - Right
CANDifferentialLock Sensors
4W Speed 4W Torque 4WD Mode
ABS On AWD/4WD B LSD On
Battery Voltage DLock Position Switch DLock Signal
DLock Switch Signal ECM Engine Speed
IND Motor Initial Diagnostic Primary Voltage
Relay Motor Relay On SOL Motor
Throttle Position VDC/TCS/ABS Vehicle Speed Sensor - L
Vehicle Speed Sensor - R Vehicle Speed Sensor - RL
CANLaneDepartureWarning Sensors
Aiming Done Aiming Result Buzzer Output
Cross Lane - Left-hand Cross Lane - Right-hand Factory Aim Pitch
Factory Aim Roll Factory Aim Yaw Indicator Lamp
Lane Detect - Left-hand Lane Detect - Right-hand LDW Inaccurate
Main Switch Switch On Lamp Turn Signal - Left-hand
Turn Signal - Right-hand Valid Position - Left-hand Valid Position - Right-hand
Vehicle Speed AT Vehicle Speed Sensor Warning Lane Left-hand
Warning Lane Right-hand X Offset
CANMeterAC Sensors
1 Range Indicator 2 Range Indicator 3 Range Indicator
4 Range Indicator 4WD Lock Indicator 4WD Lock Switch
4WD Warning Lamp ABS Warning Lamp Air Pressure Warning Lamp
Airbag Warning Lamp AT Check Warning Lamp AT M Gear
AT M Indicator AT P Mode Switch AT S Mode Switch
AT Shift Down Switch AT Shift Up Switch Brake Assistance Warning Lamp
Brake Switch Brake Warning Lamp Buzzer
Cruise Indicator Cruise Warning Lamp CVT Indicator
D Range Indicator Distance Door Warning Lamp
DS Range Indicator E-4WD Warning Lamp Engine Coolant Warning Lamp
EPS Warning Lamp Front Fog Indicator Fuel Meter
Fuel Warning Lamp Hi-Beam Indicator Key G Warning Lamp
Key **** Warning Lamp Key R Warning Lamp L Range Indicator
L/K Mas Warning Lamp Light Indicator M Range Switch
N Range Indicator NM Range Switch O/D Off Switch
O/D Off Warning Lamp Oil Warning Lamp P Range Indicator
PNP N Switch PNP P Switch R Range Indicator
Rear Fog Indicator S Range Indicator Seat Belt Warning Lamp
Set Indicator Slip Indicator Speed Meter
Speed Output Sport Indicator ST Shift Down Switch
ST Shift Up Switch Tachometer Trunk Warning Lamp
Turn Indicator VDC/TCS Indicator Water Temperature Meter
Enhanced4WD Sensors
4WD Warning Lamp Off Air Bleed Switch On Battery Voltage
Deceleration G-Sensor Engine Speed Signal (RUN) ETS Actuator Off
ETS Motor Off ETS Motor Relay Off ETS Solenoid
Front Left Wheel Sensor Front Right Wheel Sensor G-Sensor Voltage
Pressure Switch Rear Left Wheel Sensor Rear Right Wheel Sensor
Right Position Signal Snow Mode Switch Stop Lamp Switch Off
Throttle Position
EnhancedABS Sensors
Actuator Relay Battery Voltage Front and Rear G-Sensor
Front Left Input Solenoid Front Left Output Solenoid Front Left Wheel Sensor
Front Right Input Solenoid Front Right Output Solenoid Front Right Wheel Sensor
Motor Relay Rear Left Input Solenoid Rear Left Output Solenoid
Rear Left Wheel Sensor Rear Right Input Solenoid Rear Right Output Solenoid
Rear Right Wheel Sensor Rear Sensor Reference Sensor
Stop Lamp Switch Warning Lamp
EnhancedAutomaticTransmission Sensors
1st Position Indicator 1st Position Switch 2nd Position Indicator
3rd Position Indicator 4 Low Switch 4th Position Indicator
ABS Switch Accelerator Position Accessory OD Cut
Accessory Signal ASCD - Cruise ASCD - OD Cut
ATF Pressure Switch 1 ATF Pressure Switch 2 ATF Pressure Switch 3
ATF Pressure Switch 4 ATF Pressure Switch 5 ATF Pressure Switch 6
ATF Temperature 1 ATF Temperature 2 ATF Temperature Sensor 1
ATF Temperature Sensor 2 ATF Warning Lamp Back-up Lamp
Battery Voltage Brake Switch C/V Calibration ID 1
C/V Calibration ID 2 C/V Calibration ID 3 Closed Throttle Position
Coast Judge D Position Indicator D/C Solenoid
D/C Solenoid Monitor Down Switch Lever Engine Speed
F Carrier Gear Revolutions F Sun Gear Revolutions FR/B Solenoid
FR/B Solenoid Monitor F-Safe Indicator Lamp Gear
Gear Ratio HLR/C Solenoid HLR/C Solenoid Monitor
Hold Switch I/C Solenoid I/C Solenoid Monitor
L/P Solenoid Monitor Line Pressure Solenoid Manual Gear Position
Manual Mode Indicator Manual Mode Switch N Position Indicator
Next Gear Position Non-Manual Mode Switch OD Continue Switch
On/Off Solenoid On/Off Solenoid Monitor Output Revolutions
P Position Indicator PNP Switch 1 PNP Switch 2
PNP Switch 3 PNP Switch 4 Power M Lamp
Power Shift Switch R Position Indicator Select Lever Position
Shift Down State Switch Shift Mode Shift Pattern
Start Relay Start Relay Monitor Target Gear Ratio
TC Slip Speed TCC Solenoid TCC Solenoid Monitor
TCS Gear Position Keep TCS Signal 1 TCS Signal 2
Throttle Position Turbine Revolutions Unit Calibration ID 1
Unit Calibration ID 2 Unit Calibration ID 3 Up Switch Lever
Vehicle Speed Vehicle Speed - A/T Vehicle Speed - Engine
Wide-Open Throttle Position
EnhancedBCM Sensors
Accessory On Switch Alt L Signal Auto Light Sensor
Auto Light Switch Back Door Switch Compressor On Signal
Door Switch - All Door Switch - Driver Door Switch - Passenger
Door Switch - Rear Door Switch - Rear Left Door Switch - Rear Right
Door Switch All Engine Status Fan On Signal
Front Fog Switch Front Washer Switch Front Wiper Hi
Front Wiper Interval Front Wiper Low Front Wiper Stop
Fuel Lid Open Switch Hazard Switch HD/Lamp 1st Switch
Head Lamp Sasher Switch Head Lamp Switch Head Lamp Switch 1
Ignition On Switch Ignition Switch Impact Sensor
Impact Sensor Connection INT INT/L Button
Key Cylinder Lock Switch Key Cylinder UnLock Switch Key Cylinder Unlock Switch
Key On Switch Keyless Lock Keyless Unlock
Light Switch 1st LK Button Signal Lock Button/Signal
Lock Signal - All Lock Signal - Driver Lock Signal - Passenger
Lock Signal - Rear Lock Signal - Rear Door Lock Switch - Driver/Passenger
Lock/Unlock Button On Oil Pressure Switch Optical Sensor
Panic Button Passing Switch PKB Switch
Rear Defroster Switch Rear Fog Switch Rear Washer Switch
Rear Wiper Interval Rear Wiper On Rear Wiper Stop
Rear Wiper Switch Reverse Switch CAN Seat Belt Switch
Start Signal Theft Cancel Signal Trunk Button/Signal
Trunk Key Switch Trunk Open Monitor Trunk Opener Switch
Turn Signal - Left Turn Signal - Right Unlock Button On
Unlock Button Signal Unlock Button/Signal Unlock Switch - Driver/Passenger
EnhancedPowertrainNewEngine1 Sensors
A/C Pressure Switch A/F Alpha Bank 1 A/F Alpha Bank 2
A/F Sensor 1 Bank 1 A/F Sensor 1 Bank 2 A/F Sensor Heater Bank 1
Absolute Pressure Absolute Throttle Position Sensor AC Pressure
Accelerator Sensor 1 Accelerator Sensor 2 Air Conditioning Relay
Air Conditioning Signal Air Pump Control Solenoid Valve Air Pump Relay
Ambient Temperature Switch AT OD Cancel AT OD Monitor
Atmosphere Pressure Sensor Auxiliary Cont S/V BARO Sensor Present
Base Fuel Schedule Battery State Of Charge Battery Voltage
Brake Switch Brake Switch 2 Calculated Load Value
CAN Circuit 1 CAN Circuit 2 CAN Circuit 3
CAN Circuit 4 CAN Circuit 5 CAN COMM
CAN Control VC Switch Cancel Switch Closed Throttle Position
Closed Throttle Position Switch Clutch P/P Switch Coast / Set Switch
Cold Start Coolant Temperature Cooling Fan
Corrected Idle RPM Corrected Ignition Timing Crank Position
Cruise Lamp Distance Switch EGR Control Solenoid Valve
EGR Temperature EGR Volume Control Valve Engine Mount Travel
Engine Oil Temperature Engine Speed EVAP System Pressure
Exhaust Gas Temperature Bank 1 Exhaust Gas Temperature Bank 2 FPCM
FPCM Driver Voltage FPCM F/P Voltage FTFMCH Mode
Fuel Control Valve - Cylinder Fuel Control Valve - Engine Fuel Injector B1
Fuel Injector B2 Fuel Injector EG Start Fuel Level
Fuel Pressure - Cylinder Fuel Pressure - Engine Fuel Pressure Sensor
Fuel Pump Relay Fuel Tank Temperature Fuel Temp - Cylinder
Fuel Temp - Engine Fuel Temperature Heated O2 Monitor Sensor 1 Bank 1 Lean
Heated O2 Monitor Sensor 1 Bank 2 Lean Heated O2 Monitor Sensor 2 Bank 1 Lean Heated O2 Monitor Sensor 2 Bank 2 Lean
Heated O2 Monitor Sensor 3 Bank 1 Lean Heated O2 Monitor Sensor 3 Bank 2 Lean Heated O2 Sensor 1 Bank 1
Heated O2 Sensor 1 Bank 2 Heated O2 Sensor 1 Heater Bank 1 Heated O2 Sensor 1 Heater Bank 2
Heated O2 Sensor 2 Bank 1 Heated O2 Sensor 2 Bank 2 Heated O2 Sensor 2 Heater Bank 1
Heated O2 Sensor 2 Heater Bank 2 Heated O2 Sensor 3 Bank 1 Heated O2 Sensor 3 Bank 2
Heater Fan Switch I/P Pulley Speed IACV - Idle Up
IACV-FICD Solenoid Valve Idle A/V Learn Complete Idle Air Control Valve - AAC/V
Idle Long Fuel Trim Ignition Switch Ignition Timing
Ignition Timing Cylinder #1 Ignition Timing Cylinder #2 Ignition Timing Cylinder #3
Ignition Timing Cylinder #4 Injector Pulse Bank 1 Injector Pulse Bank 2
Intake Air Temperature Intake Valve Solenoid Bank 1 Intake Valve Solenoid Bank 2
Intake Valve Timing Bank 1 Intake Valve Timing Bank 2 Lo Speed Cut
Load Signal Long Term Fuel Trim Main Switch
MAP Sensor MAS A/F Sensor Bank 1 Mass Air Flow
Mass Air Flow B1 Mass Air Flow B2 Mass Airflow
OD Cancel Solenoid Valve OD Switch P/N Position Switch
POS Count Power Steering Signal Purge Control Solenoid Valve
Purge Regulator Control Valve Purge Volume Control Valve Radiator Temperature
Resume / Accelerate SCB/V Control Solenoid Valve Set Lamp
Short Fuel Trim Start Signal SWIRL Control VC Switch
SWIRL Controller Solenoid Valve SWL C/V Bank 1 SWL/C Position 1
Target Fan RPM TCC Solenoid Valve TCC Switch
Throttle Position Throttle Position Throttle Position Sensor 2
Throttle Relay Throttle Sensor 1 Throttle Sensor 2
TK_MM VTC Duty Exhaust Bank 1 TK_MM VTC Duty Exhaust Bank 2 TK_MM VTC Duty Intake Bank 1
TK_MM VTC Duty Intake Bank 2 Travel After MIL Turbo Boost
Vacuum Sensor 1 Vacuum Sensor 2 VARI Duct Solenoid Valve
VARI Resolution Solenoid Valve VC/V Bypass Vent Vehicle Speed
Vehicle Speed Cut Vent Control Valve VIAS Solenoid Valve
VT Cont Learn VVL Solenoid Valve VVL Solenoid Valve - Exhaust
VVL Solenoid Valve - Intake Wastegate Solenoid Valve Bank 1 Wastegate Solenoid Valve Bank 2
EnhancedPowertrainNewEngine2 Sensors
4 Gear Switch 5 Gear Switch A/C EVAP Temperature Sensor
Accelerator Position Sensor Accelerator Switch Actual CR Pressure
Actual Injector Quantity Actual Intake Timing Air Conditioning Signal
Ambient Temperature Switch BARO Sensor Battery Voltage
Brake Switch Brake Switch 2 C/SLEEV Position Voltage
CAM Position Pump Coolant Temperature Cooling Fan
Cooling Fan High Cooling Fan Medium Crank Position (TDC)
Cylinder Count Decelerator Fuel Cut EGR Volume Control Voltage
EGRC Solenoid Valve A EGRC Solenoid Valve B Engine Mount Travel
Exhaust Gas AS Regulator Voltage Exhaust Shut Switch F/Drive Temperature
Fuel Consumption Fuel Cut Signal Fuel Cut Solenoid Valve
Fuel Injector N/L Fuel Pump Relay Fuel Tank Switch
Fuel Temperature Sensor Full Accelerator Sensor Glow Relay
Heater Fan Switch I/C Cool T Sensor I/C Fan Relay
I/C Intake Air Temperature Sensor I/C Level Switch I/C Pump Relay
Ignition Switch Injector Timing C Voltage Int/M Pressure Sensor
Intake Air Volume Load Signal Mass Air Flow Sensor
Multi AV Signal Off Accelerator Switch P/N Position Switch
Power Steering Switch Rear A/C Relay Reverse Switch
Snow Mode Signal SPILL Voltage Start Signal
SWIRL Control Solenoid Valve 1 SWIRL Control Solenoid Valve 2 SWIRL Control Valve Switch
SWIRL Control Valve Switch Open Target CR Pressure Target F Injector
Target Injector Timing TC V/N Controller Voltage TDC Count
Throttle Relay A Throttle Relay B Trans Range Switch
Travel After MIL Turbo Boost Sensor Vehicle Speed
Warm Up Switch
EnhancedABS Active Commands
Front Left Solenoid Rear Right Solenoid Rear Left Solenoid
ABS Motor Rear Solenoid
EnhancedPowertrainNewEngine1 Active Commands
Engine Coolant Temperature Fuel Injection Ignition Timing
Idle Target RPM IACV-AAC Valve Duty Cycle IACV-AAC Valve Step
Turbo Charge Pressure Purge Vent Control Valve Fuel Tank Temperature Sensor
EGR Volume Control Valve Power Balance C-VTC Target Angle
E-VTC Target Angle EGR Control Solenoid Valve Inter Cooler Pump Relay
EnhancedPowertrainNewEngine2 Active Commands
Engine Mounting
SWIRL Control Solenoid Valve 2 MAP/BARO Switch Throttle Control Solenoid Valve A
Throttle Control Solenoid Valve B EGRC Solenoid Valve A EGRC Solenoid Valve B
Glow Relay EVAP Leak Test Fuel Pump Relay
Purge Control Solenoid Valve SWIRL Control Solenoid Valve Valve Timing Solenoid
VIAS Solenoid Relay Radiator Fan Canister Drain Cut Valve
Third O2S Vent Control Valve Bypass EVAP Leak (Mode 8)
Air Pump Relay Secondary Air Cut Solenoid VVL Solenoid Intake
VVL Solenoid Exhaust Air Conditioning Relay Variable Duct Solenoid
VVL Intake and Exhaust Solenoid Engine Coolant Temperature Fuel Injection
Ignition Timing IACV-AAC Valve Opening Purge Control Solenoid Valve
EnhancedBCM Active Commands
Key Reminder Warning Fuel Lid Open Reverse Warning
Trunk/Back Door Oil Pressure Switch IMMU Power
Security Indicator IMMU Antenna Flasher Right
Flasher Left Flasher Right (CAN) Flasher Left (CAN)
Front Wiper Hi Front Wiper Low Front Wiper Intermittent
Rear Wiper Head Lamp Washer Tail Lamp
Head Lamp Low Head Lamp Hi Front Fog Lamp
Rear Fog Lamp Illuminated Dim Signal Illuminated Dim Signal (CAN)
DTRL INT Lamp Ignition Illumination
Trunk/Back Door Horn Head Lamp Hi
Power Window Down Flasher Right Flasher Left
Flasher Right (CAN) Flasher Left (CAN) Retained Power
Retained Power (Ignition) Theft Indicator Horn
Head Lamp Battery Saver INT Lamp
Ignition Lamp Chime Rear Defogger
All Door Lock Motor Driver Door Unlock Motor Passenger Door Unlock
Passenger Door Lock Driver Door Lock Motor All Door Unlock Motor
Door Lock Output Signal Door Unlock Output Signal
CANLaneDepartureWarning Active Commands
Buzz Drive System On Lamp Drive Indicator Lamp Drive
Enhanced4WD Active Commands
ETS Soleniod Valve
CANBCM Active Commands
Door Lock Test Rear Defogger Seat Belt Warning Test
Light Warning Alarm Ignition Key Warning Alarm Ignition Illumination
Interior Lamp Step Lamp Test Luggage Lamp Test
Power Window Down Flasher Horn Chirp Test
Door Lock Trunk/Back Door PSD PBD Open
Tail Lamp Head Lamp Front Fog Lamp
Daytime Running Light Cargo Lamp Corning Lamp
Front Wiper Rear Wiper Rise Up Wiper Test
Flasher Theft Indicator Battery Saver Test
Trunk/Back Door Theft Indicator Vehicle Security Horn Test
Head Lamp Retained Power Oil Pressure Switch
Fuel Fill Lid Open TPMS Warning Lamp ID Registration Warning
Flat Tire Warning Flasher Head Lamp
Panic Alarm
$325 Shipped!!!
Old Mar 16, 2007 | 06:58 AM
98MaXeDouT's Avatar
That is the longest FS thread for one item I have ever seen.....bump.
Old Mar 16, 2007 | 04:32 PM
Nietzsche's Avatar
Should I just post a link?
Old Mar 16, 2007 | 05:19 PM
zero2sixtyZ's Avatar
You embarrass me.
Private Message sent.
Old Mar 16, 2007 | 05:27 PM
Nietzsche's Avatar
pm replied
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
