View Poll Results: What grade gas do you put in your car?
93
61
50.83%
91-92
45
37.50%
89
6.67%
87
5.00%
Voters: 120. You may not vote on this poll
What grade gas do you guys put in your car?
Old Jul 22, 2002 | 03:04 AM
MaxedOut's Avatar
I use 93....
i work at a gas station and everytime i see a maxima i check to see what kinda grade gas they are putting in their car... i usually ALWAYS see them put in 87 and i get irked.. but 1 out of every 5 maxima owners put in 93 or plus (89).. so i feel alittle better..
i even saw some guy with a brand new 2k2 GLE put in regular.. i almost wanted to go out and tell him to put in 93.. oh well
then there are times whenre i see people who have Luxo cars and put in regular.. i dont understand people soemtimes.. if u can spend 45K+ on a car.. then u can put in premium grade fuel
Old Jul 22, 2002 | 03:09 AM
Nismo's Avatar
we only get 91 so thats what I use
Old Jul 22, 2002 | 05:13 AM
NickStam's Avatar
i put what the manual recommends
Old Jul 22, 2002 | 06:04 AM
2k2kev's Avatar
It's chrome alright...
I've only used 89, get great gas mileage, never hear a knock or ping... I'm not wasting the extra $3/fillup for 91.
Old Jul 22, 2002 | 06:22 AM
Lime's Avatar
my manual recommends "premium," which, around here, is 93+ heh. Sometimes I fill up with some 94 for s&g.
Old Jul 22, 2002 | 07:03 AM
maxxed's Avatar
You don't hear knocking because the car has a knock sensor. The ECM had to retard timing to eliminate the knock, therefore reducing power and gas mileage.
Old Jul 22, 2002 | 08:48 AM
Vyrus's Avatar
I put in what the car recommends... which also happens to be premium.
-Cyrus
Old Jul 22, 2002 | 08:55 AM
ivelweyz
-Cyrus
Yeah but premium fuel from some gas stations is worse crap than the cheapest fuel in another gas station. For example Clark has 100 octane but I would rather use Amoco 87 instead. Same with Shell their premium is worse than Amoco. Amoco Ultimate, now BP,(93) is all I use...
Old Jul 22, 2002 | 09:03 AM
mtrai760's Avatar
'Trynna' is not a word
Premium
Old Jul 22, 2002 | 09:30 AM
Lordrandall's Avatar
91+
Old Jul 22, 2002 | 10:02 AM
ms.thicknes's Avatar
Re: What grade gas do you guys put in your car?
I put in premium.....which in most cases is 91....the only 93 available is at chevron and the gas station is out of my way...so I will go there once a week or every two weeks depending on my schedule
I see no problem paying extra for the premium fuel...I think it makes the car perform at its optimum level....but that's my opinion
Old Jul 22, 2002 | 10:05 AM
costcowholesale's Avatar
always 91.
Old Jul 22, 2002 | 10:20 AM
black019's Avatar
depends on my monetary status usually i put in premium but occaisionally i put in the middle grade
Old Jul 22, 2002 | 10:23 AM
Knightmare69's Avatar
I run 92 and higher, depending on what's available. I usually run with Mobil. Sometimes, I throw in a bottle or 2 of octane booster. However, I need to run higher octane because of my chip.
Old Jul 22, 2002 | 11:54 AM
Kashoggio's Avatar
the best is the best, i took apart a engine that used ****ty gas, i dont want that any of that in my car. With just the intake valves it makes a difference
Old Jul 22, 2002 | 12:02 PM
ILoveMyMax's Avatar
i only use 87 never have had a problem, ill put in 91 or 93 if its a 5-10 cent diff but usally 87 is say 1.15 and the nexrt up is 1.30 hell no. great gas milage all day long.. only highway for me
Old Jul 22, 2002 | 12:46 PM
guido_sst's Avatar
91 is "premium" here, so that's what I use. There are a few stations in town with 92, but they're out of my way by quite a bit.
Old Jul 22, 2002 | 01:34 PM
pmg's Avatar
pmg
I always heard that premium is not cleaner, just not as explosive (so no knock) w/ higher compression or boost. Car and Driver recently did an article w/ dyno tests on different grades of fuel. Most cars were unaffected. My maxima is - I calc'd lower milage (3-4 mpg) w/ low grade fuel vs. premium. I only use premium now.
Old Jul 22, 2002 | 01:47 PM
NYCe MaXiMa's Avatar
nothing but 93
the difference in 10-15 cents per gallon isn't that much, even when you fill up a full tank.. i feel better knowing my car is fed with the better stuff..
Old Jul 22, 2002 | 02:58 PM
Triple8Sol's Avatar
I miss the .org!
So far I've only had the chance to fill up my car 2x. I used premium Chevron w/Techron, and will always use premium whenever possible.
Old Jul 22, 2002 | 04:50 PM
Eric L.'s Avatar
Correct! Some poeple think premium has "more power" than regular. Technically no, it just resists detonation better, so your engine can achieve higher compression.
I use premium as well, but honestly I have never noticed a performance difference or mileage decrease if I use regular.
Old Jul 22, 2002 | 05:13 PM
Kashoggio's Avatar
im not talking about the octane rating as much as the quality or the gas, for example Mobil gas to Wawa gas
Old Jul 22, 2002 | 05:31 PM
97GreenMax's Avatar
I always use 93.
Old Jul 22, 2002 | 06:23 PM
maxichic's Avatar
87 is recommended but i always put in 93 n my car thanks me for it
Old Jul 22, 2002 | 08:13 PM
honeyface's Avatar
I use premium
Old Jul 22, 2002 | 09:29 PM
MaxedOut's Avatar
i saw another guy today with a 2k2 GLE using 87 grade.. i wanted to yell over the itnercom to use 93..but that would be rude i did see a couple maxima owners put in 93 so i wwas happy
Old Jul 23, 2002 | 12:14 AM
capmaxima99's Avatar
When i had my 99 I always put in 92 but when i was getting rid of it i put in 87. Now that i have my 02 i put in 91 cause they dont send any 92 out my way in LA.
Chris
Old Jul 23, 2002 | 02:10 AM
Majisto's Avatar
The 2k2 Maxima requires the premium grade gasoline if I remember correctly. Even if it doesn't, it should, because higher octane is certainly nice in a high-performance engine like the VQ 3.5 Liter (I know it's not technically high-performance, but you show me an N/A 3.5 Liter from the factory putting out 255 HP, while having incredibly fuel economy at a cheap price). You don't technically need high octane until you are lowering the compression to run a supercharger (Remember, all a higher octane gas means is that it will not detonate or explode early before it is ready to combust. The lower the compression, the easier it is for it to detonate early), but you may as well play it safe and run the higher octane. Early detonation = Suck, and timing retard also = Suck! You want to get as much horsepower/torque out of the engine as you can, to show those ricers your tail-lights
Old Jul 23, 2002 | 03:12 AM
carnal_c30's Avatar
Former Sponsor
show ricers 2k2 rice taillights?
I always use the highest grade i can find (91)... i dont mind spendign a bit more- maybe if my car was stock i'd worry less but when my car is like it is I'm supersensitive haha
Old Jul 23, 2002 | 05:31 AM
Cumalot's Avatar
Always the highest grade possible.
Old Jul 23, 2002 | 08:31 AM
Eric L.'s Avatar
I thought it was the opposite: high compression engines require high octane gas because compression increases heat within the cylinders, increasing risk of detonation. That is why high performance engines tend to have high compression (10:1 or above) and require high octane gasoline. I don't have an S/C so I dunno about compression
modifications, but I am fairly certain about the relationship between compression and octane.
There are some high performance engines that use regular. GM's Northstar V8 uses regular, as does the Honda Accord 200hp V6. If you think about it, it is smart engineering...regular is so much cheaper than super.
Old Jul 23, 2002 | 01:25 PM
laba's Avatar
Differences in Brands?
I use Mobil, 93. Anyone find any positives or negatives with any particular brands? Texaco, Shell, US Gas, etc? Just curious.
Old Jul 23, 2002 | 01:33 PM
BrianV's Avatar
When in Cali I ran 91, now I run 93.
All it does is resists more compression and I doubt our cars would really detonate on 87 at stock, but just to be sure I'd put at least 89 in. The differece between 91 and 93 in our cars is non-existant.
However, I once rented a 2k2 Maxima when my car was in the shop. It came with Hertz Brand 87 Octane gas. Like any normal org member I drove the **** out of it because it was a rental. 200 miles into that tank the CEL came on (only 600 miles on odometer). The CEL said knocking.
I did not remove the code, put premium in for the next tank and almost instantly the light shut off.
Thus, in 2k2's I would not put 87 in.
Old Jul 23, 2002 | 02:20 PM
ThisMax2NV
I use the good stuff!!
Rocket Fuel!!!!!
Old Jul 23, 2002 | 02:29 PM
mzmtg's Avatar
Minister of Silly Walks
Where I live, 91 is 10 cents more than 89. So, you put in 30 GALLONS per fillup?
That would make it $3 more per fillup...
Old Jul 24, 2002 | 05:31 AM
darrick's Avatar
Dallas Nissan Enthusiast
well I have a VG
and I run frg from time to time but on the weekend its 93 baby
Old Jul 24, 2002 | 05:49 AM
Sprint's Avatar
obviously your use of gas and you screen name don't go together..
Old Jul 24, 2002 | 05:51 AM
Sprint's Avatar
Originally posted by maxichic
87 is recommended
not its not .. 91 is recommended
Old Jul 24, 2002 | 07:01 AM
2k2kev's Avatar
that's where you live...
I put in 16 gallons, do the math and get a lollipop.
(about 18 cent difference)
Old Jul 24, 2002 | 07:07 AM
Sprint's Avatar
people like you don't usually keep your car after 100k so you see no problems and its not you that has to deal with your stupidity
