Help with transmission drain plug
Old Jul 24, 2002 | 03:42 PM
bmxsteve's Avatar
Hey, I've got some redline manual tranny fluid ready to go in, but I cant fit the right sized wrench on the drain bolt. Does anyone know specifically what size wrench will fit it? 12mm slips, 11mm too small, 7/16" too small, 1/2" too big. So what do I do?!! Please help, thanks
Old Jul 24, 2002 | 04:01 PM
Keven97SE
Re: Help with transmission drain plug
Sounds odd. I think I always used a 12mm. Sounds like you either have a non-OEM bolt or it's messed up. Can you fit a crecent wrench?
Old Jul 24, 2002 | 04:59 PM
MAXINXS's Avatar
My bolt was stripped. What I did was remove the single screw in the park/neutral position switch and pull that out to drain the tranny. If you decide to do this carefully pry from the larger area of the sensor because it can brake easily. I found out the hard way. Prepare yourself because that oil will shoot out like projectile vomit.Good luck.
Old Jul 25, 2002 | 02:14 AM
TurDz's Avatar
Yeah I've heard the tranny oil plug is a pain to get out. Nismo and Iilac actually stripped their bolt...
Old Jul 25, 2002 | 02:31 AM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Yes, that bolt is a ***** to get off. I still haven't got my redline in yet....
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
markevans999
Sep 10, 2015 04:29 PM
