thank you Nissan for doing something very right
Old Jul 29, 2002 | 12:57 PM
Frank Fontaine's Avatar
the A/C on my 98 SE gets a 5-star rating. Always ice-cold even with the R134a, never any problems. I don't think I've ever seen the moisture drain from it though, where is the downtube?
Old Jul 29, 2002 | 01:03 PM
95maxrider's Avatar
Lightly modded
since we're on this topic, i think nissan screwed up my ACC on my 95 GLE. the only cold temp. is 65. 66-85 is hot. is very annoying to have to be very cold to be cold at all. is there a way to fix this? im guessing they fixed this in 98?
Old Jul 29, 2002 | 01:09 PM
SonicDust187's Avatar
I have a 98 and my AC cuts off and turns back on. Still can't find what is the problem.
Old Jul 29, 2002 | 02:06 PM
njmaxseltd's Avatar
Re: thank you Nissan for doing something very right
I have to agree with Frank here. My 99 is like a refrigerator in the summer. And I have Black Leather too!
Oh the drain tube is right under the passenger side, sort of where your passengers feet would be.
Old Jul 29, 2002 | 02:30 PM
maxichic's Avatar
speaking of ac, why is it that i have to turn the **** to at least #3 to actually feel the cold air on my body? my friends accord blows it a the same rate when set to only #1
Old Jul 29, 2002 | 02:34 PM
Vyrus's Avatar
Well, I don't have climate control, just the regular A/C but I will say it ROCKS! ICE cold when I want to freeze, and FIRE hot when I want to burn.
-Cyrus
Old Jul 29, 2002 | 02:36 PM
NYCe MaXiMa's Avatar
Re: Re: thank you Nissan for doing something very right
yeah
my A/C is cold as hell I charged it last summer when I got the car, it's been very good to me.. my car is black with tan cloth, very cold inside though
Old Jul 29, 2002 | 02:37 PM
maxichic's Avatar
-Cyrus
well have u ever put any stuff to clean the inside of ur vents, i heard if u do that then it clears them up and more air comes out, that true?
Old Jul 29, 2002 | 02:41 PM
Vyrus's Avatar
I don't think anything can really clog up in an automotive air vent... I wouldn't believe it were I you.
-Cyrus
Old Jul 29, 2002 | 03:04 PM
BrianV's Avatar
I have a 97 and it sucks in Texas, my friend has a 99 and it also sucks in Texas.
Works fine in cooler temps though.
Old Jul 29, 2002 | 03:31 PM
02MaximizedVQ's Avatar
I have a 2k2 SE. When the temperature outside is 85 or higher it doesn't cool very well at all. Unless you drive around for about 30 minutes. Then it gets cold. When its less than 85 degrees or so it gets cold after about 5 minutes, especially at night. I can't understand this.
Jesse
Old Jul 29, 2002 | 03:34 PM
maxichic's Avatar
Jesse
same thing in my 97gxe
Old Jul 29, 2002 | 06:07 PM
MIXXMAX's Avatar
Yeah...ever since I got my A/C charged last year, the air is "ice cold". Very big difference from before. In the summertime, I use my A/C almost every time I get in the car!
Old Jul 29, 2002 | 06:44 PM
SR20DEN's Avatar
VQ Wizard
Jesse
The problem with the AC in the 2k2 is that for one there isn't enough insulation on the low pressure side. It comes out of the compressor and is within an inch of the exhaust manifold and has hot air blasted on it from the radiator right in front. I have been contemplating adding more insulatio and a heat sheild to see if it would help when the car isn't moving. The reason it does so much better when it's moving is becasue so much more outside air flows across the condensor which brings it's temp down to better levels. When the car isn't moving that condensor gets hot and the electric fans simply can't draw enough air to keep it as cool as it needs to be.
And has any 5th gen owners noticed their compressors making noise? Mine is getting progresivly worse. My 4th gen car stayed quiet as a mouse.
Old Jul 29, 2002 | 06:48 PM
Stereodude's Avatar
2K2 owners take your car to the dealership and complain about the AC. Mine was just like Jesse's. I complained about it in passing at the dealership when I was there getting my recall work done. Apparently it had a bad O-ring. They replaced it and recharged the system. Now instead of taking like 30 minutes to cool the car down it only takes my 5 minutes or less.
The service guy remarked about how badly the AC worked when I picked it up. He couldn't believe that I hadn't brought it in earlier.
Stereodude
Old Jul 29, 2002 | 07:31 PM
Weasel's Avatar
Nothing beats R12. My 90 Accord would cool the air so much on hot days that the air coming from the vents would fog up once it got into the cabin. Of the R134a cars I've driven, my Maxima is one of the best.
Old Jul 29, 2002 | 07:42 PM
mzmtg's Avatar
Minister of Silly Walks
Has anyone here used any of the DIY recharge kits? My AC is getting less effective than it once was...
Mar 12, 2020 12:06 AM
Bernhard
Sep 14, 2015 12:49 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
coasterswim
Sep 2, 2015 07:43 AM
