6-speed tranny bolt up to 4th gen bellhousing?
Old Jul 29, 2002 | 02:16 PM
AdMax98's Avatar
Just curious if anyone has looked into this. Im always finding myself shifting for the next gear only to realize that I dont have gears left...
Old Jul 29, 2002 | 03:03 PM
see5's Avatar
On a 6 speed top speed will come in 5th. 6th is economy only.
Nismo87SE's Avatar
Re: 6-speed tranny bolt up to 4th gen bellhousing?
You do realise that the 6spd uses an entirely different shift linkage. Your going from a shifter rod to a shifter cable. But its all good.
Old Jul 29, 2002 | 03:16 PM
AdMax98's Avatar
Re: Re: 6-speed tranny bolt up to 4th gen bellhousing?
Ok I kind of figured that might be a problem. Still that would be easy enough to convert. As opposed to mounting to the bellhousing if the bolt patter is different. What about axles?
I dont drive really fast. I just like to keep a load off my engine when driving to work. I would rather drive at 2500rpm in 6th than 3000 in 5th on the freeway.
Since my tranny seems like it may be on its way out in a year or so, it would be nice if I could throw a 6spd in instead of rebuilding the 5spd.
see5: Thats the only purpose I'd want the 6th gear for anyways.
Old Jul 29, 2002 | 06:27 PM
SR20DEN's Avatar
VQ Wizard
To answer the initial question the answer is no. A RS6F51 (A) (V) has a completely different bolt pattern where the bellhousing mates to the trans. This box uses larger bolts then the other one. Your only bet is to just use the entire gearbox becasue the bellhousing side that mates to the engine is probably the same with the exception of maybe the starter and or clutch linkage.
Nismo is right about the shift linkage being different. The RS5F50 (A) (V) use the old striker rod setup that links the gearbox to the shifter. The RS6F51 uses a cable assmbly and to use it you would also have to use the gear shift assembly as well. But hey who wouldn't want that?
Old Jul 30, 2002 | 09:22 AM
AdMax98's Avatar
Cool, thats exactly what I wanted to know. Thanks!
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
Maxboy23
Sep 4, 2015 06:04 PM
Lowered_a33
Sep 1, 2015 07:49 PM
