Window Switch Choices.......?
Old Aug 2, 2002 | 07:40 PM
Ramius83
I am finally done with the 5-speed conversion and I want to play it safe when using the N20. I have a choice of 2 window switches. Tthe MSD and the Harlan Window Switch. What are the advantages/disadvantages of both? I know that the MSD unit needs to be reprogrammed to work with the Maxima, but does the Harlan need reprogrammed as well? Thanks guys.....
Old Aug 3, 2002 | 08:31 AM
RKS's Avatar
RKS
Re: Window Switch Choices.......?
The Harlan requires no additional programming or 'pills' to set the rpm points and it costs a lot less. It is, however, a simple plastic tube so the MSD window switch looks better.
Old Aug 4, 2002 | 08:15 AM
RKS's Avatar
RKS
Re: Re: Window Switch Choices.......?
Forgot one thing you may want to purchase if you decide on the Harlan:
He does not recommend hooking the switch directly to the n2o solenoids and suggests using a relay as a go-between. I bought a 30 amp auto relay fron Radio Shack for about $5.00.
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
lrb6805
Sep 24, 2015 05:03 PM
