at the track is #### a good 60Ft time ?
Old Dec 13, 2000 | 09:00 AM
Stillnmax's Avatar
i got a 2.4 for my 60ft is that good or just real ****ty?
60 - 2.4
330 - 6.68
1/8th - 10.1
mph - 70.77
1000 - 13.15
1/4 - 15.72
mph - 87.37
Old Dec 13, 2000 | 09:05 AM
Stillnmax's Avatar
b1tch i was being serious, that happend my first day so jerk off muwhahahhahahah...... not bad for an automajic?
oh yea i was thought about it after i saw someones sig and it said that they had ran 14.#@97 or something and they had a 2.4 60ft
Old Dec 13, 2000 | 09:53 AM
Francis96se's Avatar
2.4 is about what other maximas are getting maybe a little high. I don't know of any maximas getting 1.9-2.1 60' without slicks. on my 14.9 run i pulled a 2.3x 60'.
Old Dec 13, 2000 | 10:09 AM
Dave B's Avatar
Not DAVEB the parts guy
2.4 isn't good at all. I'm running the same thing. My best is a 14.91@94.3mph with a 2.41 60 foot on very bald RSAs. I hoping for atleast a 2.2 60 foot maybe 2.1 now that I've replaced my severely worn shocks with Koni adjustables in the front and KYBs in the rear. After wacthing my car on video, it was very clear that my car was bouncing and rocking on the launch and the 2nd and 3rd gear shift. My car bites much much harder with the stiffer shocks. I love it.
The rule of thumb is for every .1 you shed in the 60 foot, you'll shed almost .2 in the 1/4 mile.
Things to try next time out at the track:
-"Shallow stage"- this means creep very slowly until the stage light goes off. What this does is gives you a quicker 60 foot because you've got about 5" to accelerate before the timing beams are tripped. I haven't tried this yet.
-Drop your air pressure in your fronts to about 25psi and raise your rears to 38-40 psi.
-Keep your engine cool, run about 4-5 gallons of gas, pull out the spare and jack
-Run on your stock wheels. Big wheels slow you down.
Honestly if you have an automatic, you'll probably do no better than 2.3-2.4s because of the lack of torque and gearing. Not until you get NOS or a SC will you be able to pull 1.8-2.2 60 foots.
Dave
Old Dec 13, 2000 | 10:30 AM
AntGVR4's Avatar
Originally posted by doug
you suck big time..
1.9 - 2.2
Doug did you really run 60' times of 1.9-2.1 ?
i highly doubt you pulled a 1.9 60' ..
yes neel for automagic's like us 2.4-2.3 is all we can hope for ..
but no it's not good.. to get good times you should run like 2.1-2.0 60's
my cuz with the AWD turbo eclipse got a 1.9 60' .. so i doubt we'll get getting anywhere near there without AWD and a 5-speed...
Ant
Old Dec 13, 2000 | 11:22 AM
madmax2k's Avatar
I know of one auto Max pulling 2.0x 60 fts on 17" wheels and tires. (Kevin you are a bum ) So, it can be done...and no its not me! I run mostly mid 2.2's (best 2.23) with my 5 speed and the stock wheels/tires/suspension.
But, a 1.9x on street tires? I havent heard of that this side of an AWD or possibly a RWD car!
Old Dec 13, 2000 | 11:30 AM
SethMax's Avatar
that's about right
It's still horribly slow but that seems to be what Max's do. I usually get 2.3 or 2.4's and usually with a ton of tire spin. Best bet I've found so far is to slip the clutch at about 2000rpm and feed in clutch and throttle. About the only way I can keep the stupid thing from lighting up 1st gear but it ends up in equally bad 60ft times.
My 1/8 mile times are 9.8-9.9 range usually, can't remember my trap speed but I rememember that this guy in a highly modded Civic Si was out there pulling 10.0's and he was doing a trap speed 1mph better than mine every time. Pissed me off.
Best run in the 1/8th is a 9.7 when I was running against my roommate's Integra Type R. He did a 9.9 but bettered my trap speed.
I'm a 5spd with 225/50 SP8000's, by the way.
Old Dec 13, 2000 | 12:57 PM
SteveChicagoSC's Avatar
My best was a 2.125 on stock rims(16) and tires. n/t
n/t
Old Dec 13, 2000 | 03:59 PM
98MAX's Avatar
I get 2.08-2.12 '60 on my 17inch sumos,and with no no NOS I get like mid 2.2s
I need to run on slicks just one time with a real low slick like 22x8 in a 15 inch. I should run 13.6-13.8 @98 with that combo. I am just scared to run the slicks for some reason, like I am doing my trany any favors running now...
Old Dec 13, 2000 | 07:18 PM
JimW
I was running 2.26-2.31-->
60 - 2.4
330 - 6.68
1/8th - 10.1
mph - 70.77
1000 - 13.15
1/4 - 15.72
mph - 87.37
Back when I was running 15.2's.
I had an all time best of 2.22 when I ran my 15.1 @ 90.45 mph..
For a "good" 60' time, see my signature.
quattro helps big time
Old Dec 13, 2000 | 07:44 PM
BIGMAX's Avatar
There's nothing wrong with his times. My first time at the track I got 15.8's with 2.4 and my second time I got 15.6's with 2.3. Automatic. Beat all of those mustangs off the line.
Old Dec 13, 2000 | 08:10 PM
My 4DSC
I dunno about auto's...
but w/ my 2k 5-speed I'm pulling consistent 2.2 sec 60' times on 18" rims (stock motor).
i'm pretty sure 2.3-2.4 is about avg for the auto's (w/o major mods) cuz they're definitely alot slower off the line.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
homeyclaus
Sep 3, 2015 06:15 PM
Team STILLEN
Aug 10, 2015 04:29 PM
