Differance between closed-deck and open-deck?
Old Aug 6, 2002 | 09:33 PM
VQracer's Avatar
Hey guys haven't posted here in forever. I've moved on to greater things http://www.my350z.com
Anyways, I was wondering if the VQ35DE is open-deck or closed and what is the differance?
Thanks,
Victor
Old Aug 7, 2002 | 11:46 AM
VQracer's Avatar
bumpity bump
Old Aug 7, 2002 | 01:12 PM
bert's Avatar
Thanks to google... http://www.google.ca/search?hl=en&ie...22+block&meta=
http://www.corollaperformance.com/TechInfo/1ZZFE.html
(and there are tons more hits
Old Aug 7, 2002 | 01:57 PM
Keven97SE
Modern aluminum block engines use steel cylinder sleeves inside to let the pistons ride in. Aluminum is just to soft and would quickly wear away under the abuse of piston rings. Open-deck blocks have a space between the sleeves and the block at the top of the engine block. Closed-deck blocks have some reinforcement between the sleeves and block at the top of the engine block. In high-HP applications like forced induction, etc that can create much larger pressures inside the combustion chamber and more violent combustions, an open-deck block is weaker because it cannot tolerate as much pressure. The head gaskets (between the cylinder head and block, right at the open/closed-deck interface) tend to fail due to the movement between the cylinder and block, and the pressure blows out the side. Closed-deck blocks, being more rigid at that point, can hold in the pressure better and are more resistant to blowing out head gaskets.
I believe the 3.5L in the 350Z is just like the Maxima 3.5L block, and is an open-deck design. Should not really be a problem until beyond 400 HP. I believe Nissan tested the VQ and determined that the block fails around ~450 HP. You should be able to add significant power to the 350Z before the open-block design becomes any sort of limitation.
Old Aug 7, 2002 | 04:29 PM
turbo97SE's Avatar
hmmm. Wonder if the VQ3DETT is open deck or closed?
Old Apr 23, 2009 | 01:50 PM
bosjon01's Avatar
"Modern aluminum block engines use steel cylinder sleeves inside to let the pistons ride in. Aluminum is just to soft and would quickly wear away under the abuse of piston rings. Open-deck blocks have a space between the sleeves and the block at the top of the engine block. Closed-deck blocks have some reinforcement between the sleeves and block at the top of the engine block. In high-HP applications like forced induction, etc that can create much larger pressures inside the combustion chamber and more violent combustions, an open-deck block is weaker because it cannot tolerate as much pressure. The head gaskets (between the cylinder head and block, right at the open/closed-deck interface) tend to fail due to the movement between the cylinder and block, and the pressure blows out the side. Closed-deck blocks, being more rigid at that point, can hold in the pressure better and are more resistant to blowing out head gaskets."
I'd like to get detailed information on the proses of making a closed deck block into a closed deck block, do you know where I can find information on this? Any information my help
Thanks,
John
Old Apr 23, 2009 | 01:52 PM
bosjon01's Avatar
Sorry, I mean an "open-deack to a closed-deck"
Old Apr 23, 2009 | 02:19 PM
bosjon01's Avatar
What type of weld do they use? They have to weld steel with aluminum, right?
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
