Motor build starting very soon! :)
Old Aug 7, 2002 | 04:39 PM
turbo97SE's Avatar
Hi
I just had a patent approved! patent = $$$. So I have decided to start my engine build. I got a spare engine to start work on so I can just swap it in.
I have been searching around looking at people's configurations and not sure what I should put in for internals.
1. VQ30DETT pistons, Arias pistons or JE pistons? 9:1, 8.5:1?
2. Probably stock crank
3. Rods? (maybe Eagle or Pauter makes some, need to check)
4. Camshafts (JWT have some that work with spacers)
5. deck weld support.
6. O-ring block?
7. JWT reinforced headgasket?
Should I touch the head? Some say no need.
Hope to run 20 psi SOON! (After I break the engine in of course!)
Would appreciate any advice!
Old Aug 7, 2002 | 04:42 PM
Blu's Avatar
Blu
the tits
20 psi
ericdwong's Avatar
Wow. Let us know how things turn out...
Old Aug 7, 2002 | 04:58 PM
Whitemax's Avatar
Disco Biscuit
I say O-ring it. You might as well do EVERYTHING you possibly can now, while the engine is out the first time, than risk pulling it again. I would also work the head, while normally gains may be minimal, with 20 psi, every little bit I would think helps.
Good Luck!!
Old Aug 7, 2002 | 05:32 PM
Cutler's Avatar
That car is gonna be a monster, the first 11-sec max???????
Old Aug 7, 2002 | 05:56 PM
maxstyle98's Avatar
head work, Yes
If you don't want to do over-size s/s valves, or titanium springs/ retainers, etc. I would strongly recomend porting both the intake and exhaust side of the head. You dont even have to have it machined, open them up a little with air tools.
My friend races DSM's. 12.8 @ 108mph before, 12.505 @ 111.7mph after head work. He runs 25psi at the track. You want to run 20psi, I would do it while your in there. The air will be happy.
Old Aug 7, 2002 | 05:58 PM
maxstyle98's Avatar
P.s. Your car is the ****
Old Aug 7, 2002 | 06:06 PM
mingo's Avatar
Re: Motor build starting very soon! :)
Originally posted by turbo97SE
Hi
6. O-ring block?
valve seals might be pretty good. how bout the vq30dett crank? is it any different?
Old Aug 7, 2002 | 06:21 PM
SR20DEN's Avatar
VQ Wizard
I say make a billet deck cap and prove my theory about how much the stock internals can hold.
Old Aug 8, 2002 | 08:34 AM
Lordrandall's Avatar
Hi
Hmmm, do you own a house yet? haha
Sounds like a ton of money to spend on a Maxima.
Old Aug 8, 2002 | 11:11 AM
i30krab's Avatar
Hi
6. O-ring block?
Don't you think you can get the best advice from JWT? They are the experts and will tell you what works, how to best spend your money, and any technical info you may need.
Old Aug 8, 2002 | 12:26 PM
nupe500's Avatar
Jedi Knight
Hi
Patent for?????
Old Aug 8, 2002 | 02:28 PM
ivelweyz
Re: Re: Motor build starting very soon! :)
Originally posted by nupe500
Patent for?????
Remote control toaster...
j/k
Old Aug 8, 2002 | 02:38 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Am I the only one who thinks putting that much power in a FWD car is pure insanity? And to think, stock Maxima 5spd owners complain about torque steer ...my question is, how do you plan on keeping this beast under control?? I wouldn't be surprised if you saw like 700HP from this. How long your tranmission will last under 20psi is unknown...could be 3 seconds, or you might get lucky and get 4 seconds out of it.
Old Aug 8, 2002 | 03:28 PM
95emeraldgxe's Avatar
good luck with the project, its gonna be a bish parking it - one tap at the accelerator and your at 60
Old Aug 8, 2002 | 03:33 PM
Craig Mack's Avatar
Not really...he'll probubly have some turbo lag.
Old Aug 8, 2002 | 07:14 PM
Lime's Avatar
woooowwww keep us all informed! Very kewl!!!
Old Aug 8, 2002 | 08:15 PM
rich96max's Avatar
I dont know about 20psi on the stock crank! If your going to build it I would replace that too, its a ***** to do it all over. Just dont go cheap, build the bottom end and then get boost happy.
Rich
Old Aug 10, 2002 | 12:53 PM
Finality's Avatar
Isn't there someone in the 5th gen forum who runs 10.60?
Old Aug 10, 2002 | 01:49 PM
SR20DEN's Avatar
VQ Wizard
Originally posted by Supai91
Well Nigel you can use the internal of vq30det not vq30dett.
The vq30det has the same pistons but with low compression 93mm bore size.
The vq30dett has 87 mm bore size so this pistons aren't gonna fit.
The best way to get vq30det engine and try to swap the internal of that like pistons,connnecting rod,crank,cams spring.
All the other stuff are the same if you are talking about Arias pistons or JE you are talking about 700 USD for Arias and 1200 for JE!
Eagle doesn't do custom connecting rod for our setup and crower does that for 1025 USD
Did anyone bent a connecting rod?
I guess the answer is NO!
The Nissan has a good connecting rod and the vq30det has better connecting rod of the vq30de,you got about 372 to the wheels with the stock connecting rod and stock pistons I guess It's easy to get extra 80 hp to the wheels with low compression but there are others things that you should do,like getting MEIV or porting your heads,getting better cams to get better hp at high rpms.
I guess It's time to creat a group deal of racing pistons and racing connecting rod!
Good luck!
It was the VG30DETT with the 87mm pistons and 83mm stoke. I doubt there ever was such a thing as a VQ30DETT. They only made a VQ30DET.
VG not VQ
Old Aug 10, 2002 | 02:00 PM
ereet's Avatar
Re: Re: Re: Motor build starting very soon! :)
Ideas? New transmission Craig nailed that one, your stock one will hold up bout 5 seconds with that sort of power.
Old Aug 10, 2002 | 02:03 PM
00MAXIST's Avatar
Am I the only one that gets sexually stimulated by this much hp in a maxima.
Old Aug 10, 2002 | 06:58 PM
JDM4LIFE's Avatar
actually, i'd decide how much power exactly you want to go, and not just aim. as others have mentioned, there's gonna be added responsibility with the higher number you go. our trannies suck as they are, but if you go you'll need to do some extra beefing up the higher you go. also, i'd budget money per level. if you're gonna do an engine buildup, you should do a good full one, not just piston/rod combo. you could easily be able to bore and stroke your engine with getting custom rods/pistons (which will be cheaper if you get it from manufacturers that already have them for us). i know arias makes pistons for our car. i'd recommend je pistons though, and crower or pauter rods. titanium valves and valve springs will give you the ability to run higher rpms, which with a turbo, is very good. i'm sure the cam that jwt has isn't a good profile for a built turbo car, even though it will be an improvement, you can see much better gains out of getting that cam made to a better grind. lastly, i'd see about getting custom axles and maybe a few other things made. they will cost lots, but you've got a good chance of breaking them if you run some serious power. again, i'd space out your money with all these mods, but they're all going to have to be done, not just one or two. only thing that could be neglected for now is heads. you can always pull those off after the buildup and redo those. your main gains will be from the engine and your main safety concern will be the axles and tranny. good luck!!
phew.... that was a long post
Old Aug 10, 2002 | 08:01 PM
ereet's Avatar
I was under the impression the amount you could bore a VQ30DE was negligable. Stroke was a different story but nobody's done it yet (3.3 litre?).
Old Aug 11, 2002 | 02:09 AM
BriGuyMax's Avatar
I don't know why you guys seem to think that our manual trans can't handle a lot of power.
I have yet to hear of even ONE case of a maxima's input shaft failing from the stress of too much power.
I have heard of broken drive axles from the use of slicks...but they are few and far between.
Most maxima 5-speed trans failures are due to DRIVER ERROR in shifting....NOT TOO MUCH POWER.
It's not like we have an all-wheel-drive that puts TONS of stress on the trans on launches...we harmlessly spin our tires....
Old Aug 11, 2002 | 07:37 AM
SuDZ's Avatar
As far as the tranny goes would the treatment that you dip the peices into to make them stronger help hold up? I think it is somethign like cryo treated or something like that. maybe someone can remember the whole name.
SuDZ
Old Aug 11, 2002 | 10:31 AM
1MAX2NV's Avatar
Here's few quick names come to mind that blew their manual tranny. I don't know if it's input shaft failing or not.
SXR7
ericwong
Keven97SE
I'm sure there are plenty of others.
Old Aug 11, 2002 | 10:38 AM
SR20DEN's Avatar
VQ Wizard
Re: Re: Re: Re: Motor build starting very soon! :)
Sorry I meant the vg30dett,Is there any vq30dett?
I guess this should be the new z engine code!
NP..
The Z code is just going to be VQ35DE for now. But if they turbo it I doubt it will be twin turbo. So it'll be called VQ35DET. Twins will only add to the cost and complexity of the car. It has been proven time and time again that single turbo setups are the way to go.
Old Aug 11, 2002 | 11:08 AM
BriGuyMax's Avatar
SXR7
ericwong
Keven97SE
add my name to that list too....BUT....all those failures were either due to "missing a gear" too many times, or improper bearing shim sizes from the factory that cause the bearings to wear out prematurely.
NONE OF THEM had an input shaft that failed.
Old Aug 11, 2002 | 04:45 PM
Pancor's Avatar
As a matter of fact, there is such thing as the VQ30DET, found in the Gloria and putting down a supposed 280 hp, and 285 ft-lbs of torque.
Theres also a direct-injection version of the 3 litre VQ that makes 240hp, and a VQ25DE that makes 210hp.
Old Aug 11, 2002 | 06:22 PM
black019's Avatar
SXR7
ericwong
Keven97SE
this ericdwong?
http://forums.maxima.org/showthread....hreadid=137909
Old Aug 11, 2002 | 06:52 PM
SR20DEN's Avatar
VQ Wizard
Who said there wasn't one?
And any direct injection engine from Nissan has a 'D' in the engine code for it. So the engine you suggested is called the VQ25DD which is in the Cefiro.
Old Sep 19, 2002 | 01:30 PM
desertmaxima's Avatar
Yea thas right cryo treat a tranny, OMG dood I dont think he has that much money at least I hope not cause damn why bother with the engine he gotz now just get a new one and build it from the grund up. But hey nigel if ya can then cryo yer tranny, but thas gonan cost a arm a leg and some teeth and very complex cause you would have to take apart yer tranny and then send in ever part to a cryo place, this can also be done for engine parts too. Here is a place that does cryo of parts cryopro its not too costly when looking at it, but if ya want take all those custom parts ya want to get and cryo all of em. I would if i had the money. Oh and i will be contacting ya in a coule months bout a possibel turbo kit fer a automagic, my borther has my max in Albuquerque and I could have him drive it up to PFI so they can do up a kit for it in the next coming months hopefully if all goes well, Good luck and may the force be with ya
Old Sep 19, 2002 | 01:40 PM
Jeff92se's Avatar
I'm needing a caw
I would see if you can add some oil squirters ala VG30DETT Z32 engine. And maybe see if you can somethow upgrade the oil pump's pressure and/or capacity. With that much psi, heat is going to be the #1 enemy. Seriously consider getting your pistons and conbustion chambers done in some type of thermal coating. Try to get some exhaust valves that are sodium filled / inconel. Also consider getting the sides of the pistons coated in a dry film moly coating also. Just some thoughts.
Old Sep 19, 2002 | 03:06 PM
Maximamike's Avatar
Jeff Hubert runs 11.9 @ 119 in his Max. He wins.
Old Sep 19, 2002 | 04:08 PM
MaxSpeedSE's Avatar
Good luck, please make this work...
Old Sep 19, 2002 | 04:42 PM
maximaracer28's Avatar
You dont have to take apart your tranny to get it cryo treated...place in mass called hekiniem (might be bad spelling) cryo treated my friend tranny, his clutch and flywheel and even powder coated the tranny silver for like $700...only thing is you have to replace the seals cause during the process they tend to break apart etc and harden cause of the temperature...
Old Sep 21, 2002 | 01:46 AM
JDwyer2821's Avatar
No it cost like $350
Old Sep 21, 2002 | 03:16 AM
I heard that theres a new car in the lawn and the pretty red car in your sig is gone?
Old Sep 21, 2002 | 06:09 AM
JDwyer2821's Avatar
Lies all lies Damm it Maybe another red car replaced it
