Important question, please respond!!!!
Old Dec 13, 2000 | 06:48 PM
Slickismax's Avatar
Today Eric was driving his 97 Max and his ABS went out. The light is on constantly and we don't know what happened. It is really snowy and Icy here, and he is lowered 2.5" on GC's with 18"s. We reset the ECU from under the dash/center console, but it didn't work. Any ideas? We also checked the fuse in the fuse panel and under the hood. Help!
Old Dec 13, 2000 | 06:54 PM
UMD_MaxSE's Avatar
Got Bent?
Perhaps the ABS really did fail. Get the ABS pump checked out. Hope it is not serious.
Old Dec 13, 2000 | 07:10 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i agree...looks like there is a problem with the ABS pump...
Old Dec 13, 2000 | 09:10 PM
The_quorum's Avatar
Last winter...
If I was spinning my wheels or rocking the car to get out of the snow/ice the ABS light went on too. I noticed I can set it off if I spin the tires in snow, hit the brakes till they stop, then spin and stop. After about 3-4 times, the ABS light comes on. It turned itself off after about 50 miles on every occasion.
Old Dec 13, 2000 | 09:20 PM
Jeff92se's Avatar
I'm needing a caw
Quarum is probably right. But on the 3-gens, you have an seperate ecu located in the trunk. It has a led just like the main ecu. It will blink a certain #. You look this # up in your fsm and it will tell you where the error code happened. ie.. 5 blinks means left front wheel sensor.
Turn on car, drive over 25 miles per hour for 1 min. Park car but don't turn it off. Open trunk and look on the right upper side(under the pass side rear speaker). Look for a red led and then count the # of flashes.
this is for a 3-gen, 4-gens might be different.
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
