Attn: SteveChicagoSC ->
Old Aug 21, 2000 | 03:01 PM
JJW95SC's Avatar
What exactly is the PROGram. Where can I get it. How much is it. Is it worth it.
JIm
Old Aug 21, 2000 | 03:56 PM
Eman97SE
Not SteveChicagoSC, but...
I saw a post of his recently that quoted around 16hp/trq for a SC'd Max, and the cost was around $800 plus dyno time. Go to http://www.racersgroup.com/program/theprogram.htm for more info.
Old Aug 22, 2000 | 06:07 AM
Eman97SE
Gotta disagree...
If you go to the For Sale forum, you'll notice a JWT ECU for sale. The add says less than 10hp. On the other hand, SteveChicagoSC say you can get "near" 20hp on a NA engine and around 16hp on a SC'd using the Program.
Old Aug 22, 2000 | 06:18 AM
Eman97SE
Yep...
Sounds like you have to put in alot of dyno time to get the Program dialed in. I wonder if the other guy just slapped it on?
Old Aug 22, 2000 | 06:22 AM
Eman97SE
$800 = 1hp = OUCH!!!
Old Aug 22, 2000 | 06:38 AM
SteveChicagoSC's Avatar
These guys pretty much covered it..
The software also has some NOS capabilities.
MadMax got as much as 22 hp on his NA motor.
You can bump up the timing and lean out the fuel more on an NA motor.
Old Aug 22, 2000 | 06:44 AM
Eman97SE
How about your pulley?
Is it custom, or something you purchased? TIA.
Old Aug 22, 2000 | 07:45 AM
Re: How about your pulley?
It's one size smaller than the stock one. You can purchase it through vortech. I'm at about 7.5 to 8 lbs. of boost. I bought mine used from Loren. He's going with the 3.33 pulley which gives him about 9 lbs. I think.
Vesaijan
Feb 27, 2002 01:03 PM
Empz
Sep 15, 2001 11:09 AM
